Old 05-21-2016, 09:58 PM   #1
Default Antenna removal ?
I have a VHF antenna that came with my boat, installed by previous owner.
I want to remove it as I will not be using. Antenna was part of a Standard Horizon CMP25B Remote Second Station Microphone setup.
The antenna is a Shakespeare 4ft model mounted on side of the center console on a bracket. My issue is the coax the runs from antenna goes through a small hole on side, into the interior of center console and then plugs into some type of black junction box, with a PL-259-G Standard Marine Radio - Antenna Connector attached to the end of the coax.
To remove the antenna from the exterior of console, I'm going to have to snake the coax through the small hole n the interior console sidewall. To do that I need to remove PL-259-G connector on the end of coax.
I don't see how that PL-259 connector plug can be removed from the coax without cutting? Can those connector plugs be reinstalled to the coax later should I need? Looks like a standard coax connector plug.
Thoughts?
Old 05-22-2016, 04:48 AM   #2
Default Yes
They can be repaired after the plug is cut off. There are screw in plugs available that just use compression but the better way is to solder it.
bigdog (05-22-2016)
This page was generated in 0.27423 seconds
