Old 07-31-2018, 06:44 AM   #1
mcdude's Avatar
Default Toilet Sweat
They say there are no dumb questions so here goes......
On these muggy days, the water coming up from the well is so cold that it causes the toilet (and some pipes in the basement) to sweat profusely leaving a puddle on the floor. Any ideas on how to minimize this?
Old 07-31-2018, 07:14 AM   #2
brk-lnt
brk-lnt's Avatar
Warm the water to minimize the temp differential. An electric instant water heater, set to only come on at certain temps, would take the chill off of the incoming water and reduce the problem.
Or, insulate everything that is sweating to prevent the cold/moist outside air from contacting these plumbing components.
[insert witty phrase here]
Old 07-31-2018, 08:07 AM   #3
rozbeezer
Default fix toilet sweating
There are two things you can do:
1. Add a mixing valve and use some hot water to fill the tank.
2. Buy an insulated toilet tank. They have foam installed inside the tank keeping the outside of the tank from getting so cold.
You can buy a plastic tray which will fit under the tank on most toilets to catch the water. This doesn't solve the problem, but keeps the floor dry.
rozbeezer is offline   Reply With Quote
Old 07-31-2018, 08:41 AM   #4
HellRaZoR004
After reading the post I understand, my mind went all over with the title.
I would start with insulating the pipes to see if it helps, pretty cheap and easy to do.
Old 07-31-2018, 09:17 AM   #5
swnoel
Dehumidifier for the basement and mixing valve for the toilet.
Old 07-31-2018, 09:28 AM   #6
Exactly the opposite actually. The water is too cold now.
Old 07-31-2018, 10:47 AM   #7
HellRaZoR004
For the toilet, yes. For the pipes in the basement that would keep the moist air off them. Sounds like a multi-pronged approach.
Old 07-31-2018, 11:06 AM   #8
Bear Islander
Bear Islander's Avatar
Toilet tank insulator kit from Amazon
https://www.amazon.com/Keeney-K836-2...70_&dpSrc=srch
You can use pipe insulators for the sweaty pipes.
Old 07-31-2018, 11:21 AM   #9
donmac
Had that problem at my place in CH, mixing in some hot water resolved the issue.
'Believe me, my young friend, there is NOTHING— absolute nothing— half so much worth doing as simply messing about in boats.'
donmac is offline   Reply With Quote
Old 07-31-2018, 12:39 PM   #10
The Real BigGuy
Had the problem once. I drained the tank, cleaned the walls and installed thin styrofoam sheeting along the walls and bottom. Was a pain to cut & keep trimming until it fit but it worked. Took me most of a day. If I had to do it again I’d just buy an insulated tank or a new toilet that had one.
Old 08-01-2018, 07:19 AM   #11
Can't help myself with this one .
Back in the early '80's, when remodeling the bathroom, to eliminate this problem, they did number 1. (Sorry, it begged to be said ). It did in fact eliminate the problem.
Old 08-01-2018, 07:31 AM   #12
Question Separate System for Toilet?
They say there are no dumb questions so here goes......On these muggy days, the water coming up from the well is so cold that it causes the toilet (and some pipes in the basement) to sweat profusely leaving a puddle on the floor. Any ideas on how to minimize this?
Install a pump, and draw water from the lake?
Old 08-01-2018, 07:50 AM   #13
kauriel
We are having similar issue with other pipes in our house and earlier this week plumber told us to run AC when it is humid. Thankfully we can remotely control it so now I just need to setup humidity sensor.
kauriel is offline   Reply With Quote
Old 08-01-2018, 08:08 AM   #14
Lightbulb "Defrost" Mode...
Aim a small "muffin fan" ($10 new) at the tank to elevate the temperature of the water inside.
Old 05-25-2019, 04:13 PM   #15
rozbeezer
We installed insulated tanks which solved the problem when we switched from lake water to a well. Available for Toto. Not sure about other
Brands.
Old 06-14-2019, 12:31 PM   #16
An AC will fix the sweating problem but you do not remotely have to run it if your not at the house. It will only start sweating when you are there flushing it introducing cold water into the tank. If the toilet has sat un-flushed on a 90 degree humid day it won't sweat the water inside it will be warm already.
Old 06-14-2019, 05:17 PM   #17
Top-Water
Some people call them ass gaskets.
Good thing you added the word "fan" to the sentence or this would be begging further explanation.
Old 06-14-2019, 06:28 PM   #18
Wifi-1
Wifi-1's Avatar
Here I am, waiting for FLLs suggestion to save water and not flush it
Old 06-14-2019, 06:46 PM   #19
joey2665
joey2665's Avatar
And him suggesting wrapping the plumbing with foam noodles.
Old 06-14-2019, 09:42 PM   #20
Barney Bear
Default Good Suggestion
If properly installed on the pipes, foam noodles should help do the job!
This page was generated in 0.34019 seconds
