Old 10-22-2015, 09:54 AM   #1
Showem
Default Oil extractor?
Looking to buy a good extractor for removing oil does anyone have any recommendations? Thanks in advance
Showem is offline   Reply With Quote
Old 10-22-2015, 10:51 AM   #2
HellRaZoR004
Kind of pricey but I've used this one before with great results.
http://www.amazon.com/dp/B008F943DS/...I2LSFDK500OP6T
I've used this one also and found the connections were lacking as it popped off a lot (making a mess). I had to add hose clamps to get enough suction...plus I needed to stop half way through and empty it as it would fill up before all the oil was out.
http://www.amazon.com/Mityvac-7400-L...0_SR160%2C160_
Old 10-22-2015, 11:45 AM   #3
I've been using one of these for 13 years and it works great. Juyst make sure the oil is warm and it will pump the oil out in a couple of minutes.
https://jet.com/product/detail/8b8c8...kRsaAsN28P8HAQ
Old 10-22-2015, 12:13 PM   #4
Woodsy
I second the MityVac.... that thing works great! No matter what way you go, the warmer the oil, the easier the extraction.
Woodsy
Old 10-22-2015, 07:09 PM   #5
JPC
Default Oil Extractor
Try West Marine. They have a 6.9qt unit for $80. I've been using one for a number of yrs with no problems. Wish I'd gotten the smaller one. My engine only holds two qts.
check out this link
http://www.westmarine.com/buy/west-m...6-5l--11047123
Old 10-23-2015, 08:50 AM   #6
This is the unit I have used since 1998
:https://www.pricefalls.com/product/j...1s0aAibK8P8HAQ
Most any of the above will work well. Though they seem pricey they're about the cost of one oil change at the marina!
Old 10-23-2015, 02:00 PM   #7
After struggling with the cheaper ones for years I bought this one this Fall...Awesome
http://www.amazon.com/gp/product/B00...ilpage_o01_s00
Old 10-23-2015, 06:54 PM   #8
Default Hmmmm
Do any of these give you the confidence that you are getting all of the sludge and contamination out of your crankcase?
There is something about having the plug out and watching the oil drain to the bottom of the pan that seems right. But, I'm willing to learn from someone else's experience.
Old 10-23-2015, 07:29 PM   #9
HellRaZoR004
Depending on the type of engine you have it's pulling from the same level.
For instance, if you have a Merc 496 the dipstick line is on the opposite side of the plug.
https://www.mercruiserparts.com/Show...D+DRAIN+SYSTEM
You don't put the hose down the dipstick tube. You use the tube to pressurize the engine and the pump sucks it out through the tube.
Old 10-28-2015, 07:55 PM   #10
Good question on sludge. Pulling thru the dipstick is the only option I have. My boat is a 1997 with 1200 hours on the engine. I don't let my oil get to dirty and have always changed it at 70 hours or less so I hope not much sludge is ever there. Runs great and doesn't burn any.
Old 10-29-2015, 02:48 AM   #11
Lightbulb From "Extraction", Expect Sludge...Try a "Rinse"...
After extraction of the old oil, adding exactly one quart of new ATF (or high-detergent oil), then measuring what gets extracted should answer that question.
Check clarity of the "rinse" for sludge and contamination. The ATF "rinse" can be re-used to lubricate chainsaw bars or—like WD-40—to attack corroded hardware.
Old 10-29-2015, 09:24 AM   #12
Rich
The extractor that I have uses a small diameter nylon tube that I place down inside of the dip-stick tube. This allows me to go to the bottom of the oil pan and suck out all the oil, without leaving any on the bottom.
Will it get every drop? Who knows, but you're splitting hairs here.
This is the unit that I have:
http://www.amazon.com/America-5060-T.../dp/B001445IZ8
I also use it on my cars. It's so easy and you don't get a drop of oil on yourself if you are careful.
Old 10-30-2015, 09:18 AM   #13
Default Draining oil from a boat engine
I've been using this technique for decades!
http://blog.boattrader.com/2013/08/o...rain-hose.html
It's a lot cheaper and less mess than other methods.
This page was generated in 0.22007 seconds
