Old 04-02-2019, 06:13 AM   #1
mrtoad
Default Reputable Marine Repair Service in Lakes Region?
I have a pontoon with a damaged tube that needs to be repaired. Is there a reputable marine repair business in the Meredith/Holderness area? Thank you.
mrtoad is offline   Reply With Quote
Old 04-02-2019, 10:12 AM   #2
Default Welding? East Coast Welding
Welcome to the Forum.
It's not clear what sort of damage needs repair, but I think the long established marinas have good reputations. You can use the search function here if you have one you're looking at. Many of them will sub out specialty work usually with some sort of mark-up.
You might try East Coast Welding in Gilford. I've had custom fabrication from them that was well done and reasonably priced. I took my boat to them, but they travel all over NE. (603) 293-8384
Old 04-02-2019, 10:25 AM   #3
You could also try Hewitt Welding on Union Avenue in Laconia.
(603) 528-3213
He teaches welding at Lakes Region Community College. I have had him do work on pontoon boats and welding on aluminum trailers. The work was good and the price was fair.
Make sure whoever you use has experience and good references. I made the mistake of using someone to weld a rub rail on the outside of two pontoons and they burned holes in the pontoons.
Old 04-02-2019, 02:26 PM   #4
Outdoorsman
Seems pretty clear....
This page was generated in 0.26502 seconds
