01-09-2013, 10:45 AM | #1 |
Need snow shoveled from roof
My cousin recently purchased a home on Meredith bay and is concerned about having someone lined up to shovel the snow from the roof should we get a lot of snow this winter. Can anyone give a recommendation of someone in Meredith who is honest and reliable to do this?
01-09-2013, 05:24 PM | #2 | |
When that happens, many are seeking the same. If home was constructed correctly then there should be no issues. Just make sure homeowners policy is current and up to date. And have insurance agent read the part that covers the roof and interior contents. I know of no one that rakes such. Your best bet might be to contact some of the landscape companies. Some/many do plowing in winter. You might be able to set something up ahead of time. Also, there are independent contractors that do property management. You could try one of those. I do not have names but I have seen the pickup trucks around the Lakes Region. Welcome to the Winnipesaukee Forum. |
01-09-2013, 06:24 PM | #3 | |
I disagree with hiring a landscape company. People who have no experience on roofs do not belong on roofs. A contractor, roofing or builder can help you out or point you in the right direction. Also make sure the person you hire has insurance and has the INSURANCE company send you a binder. You can ruin a roof really quick if you do not know what your doing. You Have to start at the top and work your way down if your shoveling, with a roof rake it doesn't matter. You can send me a message and I'd be happy to take a look at your place and give you my thoughts. I have 2 jobs I'm getting ready to start in Moultonborough so I will be passing through Meredith. I am a painting contractor with all the experience, insurance and tools needed to do this type of work and a plow truck to move the snow out of the way once it is down.
"better to have a short life that is full of what you like doing, then a long life spent in a miserable way.." |
01-09-2013, 07:37 PM | #4 |
Your best bet is like BR said with a roofer...you can ruin a roof in no time if you have no clue what you are doing.I have seen it happen.
01-09-2013, 07:57 PM | #5 |
The above is correct.
Inexperienced folks can easily ruin a roof. And yes, hire someone with insurance. All good points. I stand corrected. |
The Following User Says Thank You to songkrai For This Useful Post: | ||
secondcurve (01-09-2013) |
01-10-2013, 07:27 AM | #6 |
Why don't you do like everyone else and go buy a long roof rake and just do the eaves by yourself ...... doing the eaves is all that needs to be done to keep from getting those ice dams .....which eventually can cause water back-up and water leaks. You can probably find a perfectly good roof rake at Goodwill-Laconia for just eight dollars....plus the exercise of roof-raking will probably do you some good!
01-10-2013, 08:04 AM | #7 | |
I believe the original concern was for snow removal due to the weight not from ice problems.
01-10-2013, 08:44 AM | #8 |
oldman, I just noticed that you are fairly new to posting on the forum and glad you have joined us. Have fun and enjoy the Winni Forum while making many new friends. I see you are already finding some solutions to your question. Best of luck and enjoy your cousins new home.
01-10-2013, 08:56 AM | #9 | |
The best is to use the Grace membrane after stripping all roof materials. Or move to the more expensive metal roof. But I think the original question is hiring someone to shovel the entire roof after a big snow storm. |
01-10-2013, 09:14 AM | #10 | |
We have this issue with our Maine house/camp. It has a metal roof but a it should never have had one installed. Almost flat maybe a 5 degree slope. The big storm that dropped 18" had no wind at all so we had to drive up and shovel it. Or should I say we drove, I shoveled, she played with the new puppy. Usually when there is any wind at all the majority of the snow blows off. I have had the dis-pleasure of clearing a 2 story roof. To steep to walk so it was all done from a ladder using a plastic roof rake. Great upper body workout. Unfortunately many homeowners do not understand just how labor intensive snow removal is and only see the cost, which usually means they hire whoever will do it the cheapest. Problem is they will not see those missing shingles till next spring.
01-10-2013, 02:21 PM | #11 | |
More info in building unvented cathedral ceilings is here: http://www.greenbuildingadvisor.com/...hedral-ceiling Last edited by DickR; 01-10-2013 at 02:38 PM. Reason: More info |
01-10-2013, 06:37 PM | #12 | |
Venting, of course, is a crucial key to a good roof. Some/many just don't understand how to construct a new house with proper venting. I see many new homes now with ice/water shield (Grace) over the entire roof. Also, some now spray a thin layer of foam on the inside of all roofs. And I don't see any venting or little venting. Those that read my Munchkin story - the same home - built by one of the better known builders in the Lakes Region - that home had the roof leak the 2nd year. Insurance claim $8,000 for inside home. The entire roof was ultimately removed and redone. Paid for by the homeowner. House was only 3 years old. |
01-10-2013, 07:36 PM | #13 | |
Yes there are a lot of so,so builders but there are a lot of homeowners who think they know best and advise the builder on how they want things done. Remember there are 2 sides to every story.
01-11-2013, 07:58 AM | #14 | |
01-11-2013, 08:07 AM | #15 | |
This house has multiple valleys all around it and holds snow all winter. It is just shy of needing a air exchanger but no ice dams or water. I would think that having the most insulation possible on the roof is the best option. But I'm a painter not a builder.
01-11-2013, 12:09 PM | #16 | |
Nearly all cases of ice damming at the edges of roofs are due to warmth getting to the roof surface. Much of the time this is due to heat carried by air leakage from conditioned space into the attic (vented attic) or the roof cavity in the case of a cathedral ceiling. Can lights in the upper floor ceiling are notable heat leaks, even those rated "air tight" (AT), and from a building science point of view are generally a bad idea in those locations. But any air leak that carries heat from conditioned space to the roof deck contributes to conditions that lead to ice damming. More and more attention is being given to building science issues, and some builders have learned how to get it right, but sadly some still just build the way they've always done it. Insistent homeowners who prefer form over function also are part of the problem. |
The Following 3 Users Say Thank You to DickR For This Useful Post: | ||
01-11-2013, 12:32 PM | #17 | |
When my cathedral ceiling was built they used foam baffles the full length of the ceiling before insulation was added. The baffles channel cold and hot air to the ridge roof vent for proper ventilation. On one side the baffle goes halfway in the ridge vent and then the other side overlaps that one. I have never had any ice damming on my roof.
01-11-2013, 02:23 PM | #18 |
01-11-2013, 09:55 PM | #19 |
Thanks for all the advice everyone. I told my cousin about this thread and he has checked it out. He will make arrangements for shoveling when and if necessary. He has your info Belmont Resident. I have to think that the house will be ok since it survived this far. thanks again
The Following 2 Users Say Thank You to oldman For This Useful Post: | ||
Belmont Resident (01-12-2013), songkrai (01-12-2013) |
01-12-2013, 08:44 AM | #20 | |
01-12-2013, 09:05 AM | #21 |
got that covered...
...drain the water out of the trap, and replace with RV antifreeze.
01-12-2013, 10:42 AM | #22 | |
Agree 100%
01-13-2013, 11:54 AM | #23 |
Lots of times ice dams occur not because the roof wasn't "raked" but because of issues with the attic space. Attics idealy need to be very well vented through the soffits and in the winter VERY COLD! An attic should preferably average the same temperature as the outside air. When it's this cold snow will not be as likely to hit the roof and begin melting which eventually forms an ice barrier. After $15,000 worth of ice damming issues two winters ago I became very educated in this subject. Most folks attribute ice dams to the gutters backing up which does happen however a home can still have "damming" even without gutters installed.
01-13-2013, 03:21 PM | #24 | |
The Following 2 Users Say Thank You to sky's For This Useful Post: | ||
watrskir (01-13-2013), Winnisquamguy (01-13-2013) |
01-13-2013, 04:21 PM | #25 |
There are also contractors who want to do what he wants to do not what the homeowner wants to do. It does work both ways.
The Following User Says Thank You to tis For This Useful Post: | ||
old coot (01-24-2013) |
