Old 03-09-2016, 01:06 PM   #1
radiocontester
radiocontester's Avatar
Default Seadeck Swim Pad
Does anyone have any experience with this product? http://www.seadek.com/
Thanks.
radiocontester is offline   Reply With Quote
Old 03-09-2016, 01:31 PM   #2
Was just looking at this the other day myself. Our new boat has a vinyl floor, which my dog hates, so we're looking at our options.
Old 03-09-2016, 01:41 PM   #3
Salty
I had samples sent. Seems like nice material. Planning to install on swim platform this spring.
Sent from my XT1254 using Tapatalk
Salty is offline   Reply With Quote
The Following User Says Thank You to Salty For This Useful Post:
radiocontester (03-09-2016)
Old 03-09-2016, 02:08 PM   #4
How's the pricing?
Old 03-09-2016, 02:18 PM   #5
Winnisquamer
I found seadek lifts up on the edges after a season or two. Look into other companies like Gatorstep or deckedance instead. Seadek was dropped from a lot of high end surf/wake boats for that reason as well.
Customer service at seadek was terrible also. They initially cut the pattern to my boat incorrectly and tried to tell me I told them it was the wrong boat when I ordered a replacement. I forwarded the woman the exact email telling her I had a 2013 model XXXX. They didn't care, still said it was my fault, and at that point I cancelled the order and wouldn't do business with them again.
Deckedance feels better on the feet in my opinion.
Old 03-09-2016, 02:38 PM   #6
Salty
Price varies depending on size and complexity. They have templates for numerous boats.
But I have not installed the product or used it so cannot vouch for it.
Based on other's comments I may look elsewhere.
Old 03-09-2016, 03:15 PM   #7
Winnisquamer
I don't want to deter people. I am sure if you put 20 hours a season on your boat and don't beat it up at all you probably wont have an issue. I however put 150+ hours and way more just lounging around. We run wakeboards/ surfboards, ropes, coolers etc along it on top of being out 5-6 days a week. Although we are meticulous and clean the boat 2-3 times a week, that wear is a little more than "normal" wear.
The product overall to me just didn't hold up how I expected it to. I went back to OEM carpet.
Old 03-09-2016, 03:22 PM   #8
radiocontester
Great feedback in your two posts....thanks for the heads-up.
Old 03-10-2016, 09:29 AM   #9
Rich
I'm not sure of this brand is one that has the problem, but some of these products are VERY hot in the sun.
They get so hot you can't stand on the swim platform with bare feet without dowsing it with water from time to time.
I may have the brand wrong, so I hope I'm not mentioning this in the wrong thread.
I was considering this type of product as it looks great. Last year I used a carpet alternative that some venders call 'seagrass'. Here is a link:
http://www.marinecarpeting.com/marin...-flooring.html
This looks great on our boat, can be rinsed off easily, doesn't hold water like a sponge as carpet does. Oh did I mention it looks great! Downside is that it is more expensive than standard carpet.
I didn't do this on my swim platform, but it's in my whole cockpit. I had Shipshape marineworks install it for me, they did a great job! I used their 'better than teak' product to match the teak and holly used in otherplaces on my boat. There are many styles and colors available.
I'm happy to point this out as an alternative to carpet, and it may be an alternative to the seadek and other hard products. My guess is that the color could affect the temperature in the Sun as well as the marerial holding the heat.
radiocontester (03-10-2016)
Old 03-12-2016, 09:29 AM   #10
Bandrews7
Bandrews7's Avatar
I put SeaDeck on my platform last year. It is not hot in the sun, easy to maintain and was a piece of cake to install. Customer service was fantastic and the product shipped within the timeframe they told me. I plan on doing SeaDeck through the rest of the cockpit and the upcoming season or two.
"Isabethan"
Bandrews7 is offline   Reply With Quote
Old 03-13-2016, 11:54 AM   #11
Sue Doe-Nym
Would this product make sense to put on a low swim platform where the ducks like to make a mess?
Old 03-16-2016, 06:45 AM   #12
Irish Choppers
Location: Worcester MA / Meredith NH / Ft. Lauderdale, FLA
Default Sundek Products
Hi Radio,
Funny that you were looking into this product. I own a Sea Ray 220 Sundeck and just inquired about the SeaDek products. Here's the response I received. I hope you find it helpful!
Thanks for the interest in SeaDek. I'm not sure if we have a pattern that will fit your 220 SD. What happens with SeaRay & other builders is that in many cases the same patterns are used for different models over different years. As you can imagine this makes it pretty tough to know what we may be able to use for what. Most of our patterns are derived from template kits returned to us by individuals & we are often only certain about the match to that person’s particular model. That is until we are able to confirm it's matching other models & years.
Please check the dimensions of your boat to the pad drawing attached closely as our custom pads are not refundable. If it does, we may be able to use it. Please note, this estimate does not include sales tax or freight charges. The cost of this kit would be $335.00 in our 6mm Embossed or Brushed finish and $420.00 in our 6mm Faux Teak finish plus shipping and tax (if in Florida).
If not, or you are not sure, the best thing is for you to go the template route. This is a relatively simple process.
http://www.seadek.com/c-9-template-kits.aspx
We can also do a dry fit template. This is a template the actual size of the platform pad that you would lay over to see if it fits. The cost of this is $5.00 Per Sheet + shipping.
Our largest sheet of material is 39"x77" which covers approximately 18 square feet. The cost of this size sheet for custom cut pads is $335.00 + shipping for our microdot embossed material and $419.00 + shipping for our brushed teak material.
Lastly you can DIY. Determine approximately how large your area is and order the appropriate size sheets (http://www.seadek.com/c-5-sheet-material.aspx) pattern, cut and install it yourself. SeaDek is easy to cut and with a reasonable amount of care excellent results can be achieved at a considerable savings over a custom SeaDek solution.
I should mention that we do not stock custom pads or swim platform pads. They are all made to order. Due to this being our busy season we are looking at 5 weeks production time for custom orders and about 3 weeks from existing, cataloged designs.
Sheet goods for DIY are usually on hand and can be shipped right away. Please note that our faux teak material is not offered in our DIY stock sheets.
If you would like to place an order you can contact our number below and we would be happy to help you. Please let us know if we can be of further assistance.
Thank you,
Elijah Gay
Customer Service Representative
SeaDek Marine Products
5440 Schenck Ave.
Rockledge, FL 32955
321-632-4466 Phone
321-806-4389 Direct
321-632-7019 Fax
Irish Choppers is offline   Reply With Quote
Old 03-16-2016, 08:48 AM   #13
radiocontester
Thanks Irish, I appreciate you passing this along. There have been mixed reviews regarding this product (I tend to focus on the not-so-good) which has prompted me to investigate other options.
Old 03-20-2017, 12:27 PM   #14
I am having Seadek installed on my wife's boat now. I really like the way it looks and feels and from what I have seen firsthand it's a good product.
We shall see!
Old 03-20-2017, 05:32 PM   #15
elbie
Default Seadeck
Please keep us posted. I may want to install on my Jon boat whose surface is rather slick.
Thanks,
Elbie
elbie is offline   Reply With Quote
Old 03-20-2017, 06:05 PM   #16
Thanks,
Elbie
For what its worth, I have a friend who has had it on his boat on the ocean for four years now without any issues.
I'll keep you posted...
Old 03-21-2017, 09:36 AM   #17
elbie
Smile Seadeck surface
Thanks Dan,
I went on their site and requested some samples.
elbie
Old 06-30-2017, 05:17 PM   #18
Thanks,
Elbie
Here you go Elbie, the finished product!
We love it!
Old 06-30-2017, 05:19 PM   #19
Thanks,
Elbie
Here's another....
Old 06-30-2017, 06:00 PM   #20
Wow!!!
That looks great!
Was this a measure, cut and install or was there already a CAD file for your boat?
Do I dare ask how much?
I have this on a Sea Ray 220 Sundek. I have always figured it came from the factory that way.
Old 06-30-2017, 06:06 PM   #21
Wow!!!
That looks great!
Winnisquam Marine did the work. I can tell you that SeaDek sends a pattern kit, then after patterning everything gets cut. It takes a while and yes it is rather expensive....
I am going to have the front and back of my Bennington done next.
Old 12-16-2017, 04:28 PM   #22
Default Impressive Product
Wanted to bring this thread back up since my wife’s boat has had her SeaDek on for a full year. Her boat stays in the water all summer on the prevailing wind side of Welch fully exposed to sun, wind and all the elements completely uncovered and the SeaDek has held up just great. No signs of any peeling or fading whatsoever. It was a great improvement on her boat and we are very pleased with the product thus far.
My Bennington pontoon is now being patterned for bow and stern SeaDek as well as helm pads for the Captains seat and 1st mate seat as well as other little flooring upgrades utilizing SeaDek.
I can confidently recommend SeaDek. It’s great stuff when installed correctly and I give it two thumbs up!!
Old 12-16-2017, 04:44 PM   #23
Did the Bennington decking need replacement (what age), or do you see things in Sea-Dek that prompted early replacement/installation?
Old 12-16-2017, 04:53 PM   #24
Descant,
No, the Bennington flooring was in great shape, heck my boat is only a couple years old! I’m adding the SeaDek as an enhancement. I am adding it to the bow and stern outside the playpen area and also adding a couple helm pads at strategic locations mainly for looks and comfort.
Old 12-16-2017, 09:14 PM   #25
Cobalt 25
Anyone know if this product, SeaDeck, is used on Formulas? It looks like the material on our swim platform and we like it a lot.
Old 12-18-2017, 07:04 PM   #26
radiocontester
Thanks Dan, I appreciate the one year usage review!
Sent from my VS988 using Tapatalk
Youtube channel: https://www.youtube.com/user/radiocontester
Old 01-27-2018, 08:42 PM   #27
glastron guy
I had Gatorstep installed on my swim platform and have found it to be excellent so far. We like it so much that we are going to do the rest of the boat. Price was much cheaper than Sea Deck. Reviews of Sea Deck were not that good and looking at some of the boats with Sea Deck I could see evidence of it starting to peel. Have not had Gatorstep long enough to know how it will hold up.
glastron guy is offline   Reply With Quote
Old 05-29-2018, 12:40 PM   #28
Love the SeaDek so much on my wife’s boat decided to have Winnisquam Marine add it to the bow and stern of my toon. Also added a couple helm pads at the Captain and 1st mate seats. Definitely dresses it up and very comfortable on the feet, not hot at all. See pics below....
Old 05-29-2018, 12:48 PM   #29
joey2665
joey2665's Avatar
Looks Great Dan. I had the same installed on my Sea Ray and I love it, soft comfortable and never hot
The Following User Says Thank You to joey2665 For This Useful Post:
ishoot308 (05-29-2018)
Old 05-29-2018, 11:06 PM   #30
LakeTimes
Anyone have any experience on how this holds up with dogs onboard? I've been going back and forth on installing it. My only concern is the dog's nails will destroy it.
Old 05-30-2018, 04:41 AM   #31
I have a 75 lb yellow lab, absolutely no issues. It’s tough stuff!!
Old 05-30-2018, 09:06 AM   #32
dt5150
sharp looking upgrade for the bat mobile. looks nice
The Following User Says Thank You to dt5150 For This Useful Post:
ishoot308 (05-30-2018)
Old 06-06-2019, 11:18 PM   #33
Downeast
Default seadeck
Yes, Matt Resca of
supreme marine in Gilford is comfortable with decking overlay.
He is the only one in the area that has the proper equipment to digitize the cut drawing needed for a precise fit.
The Following 2 Users Say Thank You to Downeast For This Useful Post:
CooperS7777 (06-06-2019), ishoot308 (06-07-2019)
Old 06-07-2019, 03:09 PM   #34
brk-lnt
brk-lnt's Avatar
FWIW, the most common problem I have heard of with SeaDek and other foam deck coverings has been darker colors getting excessive heat in rounded corner areas. Basically, new (or well-polished) gel coat in some medium-radius corners can act like a mini parabolic reflector and concentrate some sunlight in a small spot that really heats up the darker stuff and causes it to shrink, discolor, or unstick.
SeaDek has warranted the cases I've heard about, but I believe they started to require customers to replace it with a lighter color when that is a problem.
[insert witty phrase here]
This page was generated in 0.29519 seconds
