Old 10-12-2019, 09:16 PM   #1
Prestige Worldwide
Prestige Worldwide's Avatar
Default +9,999.9 Gallons of Super Unleaded Fuel Used ⛽️
I hit a milestone today. I maxed out the gauge that measures gallons of fuel used in my SUV.
I wish I had one of these gauges on my boat. Name:  IMG_9104.JPG
Prestige Worldwide is offline   Reply With Quote
Old 10-13-2019, 04:07 AM   #2
Senter Cove Guy
Senter Cove Guy's Avatar
Default You’ll Get Better Gas Mileage
If you keep your tires properly inflated.
The Following 2 Users Say Thank You to Senter Cove Guy For This Useful Post:
upthesaukee (10-13-2019), ursa minor (10-13-2019)
Old 10-15-2019, 06:12 AM   #3
lakershaker
Default I have one on the boat
Only around 2400 gallons after 10 years... Not sure if I should be happy or sad with that!
Old 10-15-2019, 07:52 AM   #4
brk-lnt
brk-lnt's Avatar
You probably don't
But, if you are serious, there are a lot of fuel monitoring options for marine engines, particularly if your engine is newer than ~2000 or so. Most engines have at a minimum a J1939 port that you can get fuel data off of the ECU from. Newer engines will support a NMEA2000 connection, and report fuel flow data. This can be tallied by various MFDs.
My boat no longer has an analog fuel gauge, it was never very accurate, we just tally fuel usage in the MFD and call for a fill up when we get below 40 gallons or so in the tank. I can see total remaining fuel in the tank, range, and "seasonal" usage (or, if I don't reset the seasonal ticker, total fuel used).
[insert witty phrase here]
HTML code is Off
This page was generated in 0.15874 seconds
