Old 08-03-2024, 08:42 AM   #1
RoBe
Default Six Pack
Traveling through the Six Pack yesterday afternoon heading toward the Bridge had a prop hit inside the second set of markers. Initially thought it might have been a log, but based on damage it was a rock. We were well inside the second red marker slightly to the right of center. Bizer, Navionics, Depth gauge all show safe water levels. Not so. Be careful and watch your gauge in the Six Pack, it was an expensive ride
RoBe is offline   Reply With Quote
The Following 4 Users Say Thank You to RoBe For This Useful Post:
bobkatfly (08-05-2024), mcguirej (10-03-2024), Tank151 (09-23-2024), The Winster (08-04-2024)
Old 08-03-2024, 08:46 AM   #2
One of the markers could have moved…thanks for the heads up! It might be a good idea to inform Marine Patrol…
Old 08-03-2024, 08:53 AM   #3
camp guy
camp guy's Avatar
Default 6 -pack
I would like to think Marine Patrol looks at this site, considering that during the summer there are a great many posts relating directly to boating on Lake Winnipesaukee. I wouldn't expect them to be Moderators, nor frequent contributors, but an occasional check during the day might be helpful.
Just a thought.
Old 08-03-2024, 09:05 AM   #4
RoBe
I have notified Marine Patrol. Save a prop today!
The Following 2 Users Say Thank You to RoBe For This Useful Post:
camp guy (08-03-2024), Tank151 (09-23-2024)
Old 08-04-2024, 05:34 AM   #5
The OP said his chart, GPS, and depth gauge all showed safe, so we might just be talking about the standard error of GPS calculation?
What is that these days, 6-10'?
Old 08-04-2024, 08:10 AM   #6
DEJ
To the OP. Were you fully on plane or semi plowing through the area? Not knowing what type of boat you have, that could be the reason you hit a rock.
Old 08-04-2024, 11:08 AM   #7
RoBe
28’ I/O with 3 passengers @ 15 mph so I had a deeper draft going…for sure
Old 08-04-2024, 11:33 AM   #8
tummyman
Can you tell me what Navionics lake software you are using ?? Thanks...
Old 08-04-2024, 11:35 AM   #9
tummyman
Or was that picture froma Bizer chart? If Bizer, what model GPS device
are you using? Thanks
Old 08-04-2024, 11:49 AM   #10
I cannot tell a lie, Officer Obie.
I put that rock there!
Old 08-04-2024, 12:00 PM   #11
RoBe
That’s from the Navionics app on my phone.
With water levels down, that area is more shallow than I’d expect. As soon as I made impact, I checked my depth gauge and it read 6.2’
Such a bummer. No matter how much experience, there is always something to learn on the lake
Old 08-04-2024, 02:02 PM   #12
Default Damage details?
With an I/O, I curious about the damage. Usually, if there is prop damage, I'd expect some damage to the lower unit too, which can be really expensive. On an inboard, I could more easily understand damage to just the prop. I look forward to learning more about this.
Old 08-04-2024, 02:58 PM   #13
The Real BigGuy
I thought that Bizer posted several years ago about a rock in that area that only became a hazard at lower water levels.
Old 08-04-2024, 08:07 PM   #14
Woody38
Default 6 pack
Isn't a 6 pack 3 deuces atop a 409.
______________________________
The Following User Says Thank You to Woody38 For This Useful Post:
AC2717 (08-07-2024)
Old 08-04-2024, 09:30 PM   #15
Default Apologies for going astray
Sounds familiar. I never understood three carbs on an 8 cylinder engine. Shouldn't it have been four carbs?
Old 08-05-2024, 04:24 AM   #16
I believe that. That is the only place in the lake we ever hit a rock and it was inside the buoy and in the fall.
Old 08-05-2024, 10:16 PM   #17
Woody38
Default 6 pack
Not 4 carbs. Difficult to place 4 carbs on the intake manifold. That would be 8, not 6. You can check out 6 packs on some classic cars, mainly Chevy's or Dodge and Plymouth. Then there was the ram induction with 2 quads.
Nice to run 3 2-barrels running all together running all the time.
Old 08-06-2024, 07:32 AM   #18
Where is the "six pack" located? (Asking for my prop)
Old 08-06-2024, 08:50 AM   #19
Here you go, friend!
Overlake97 (09-30-2024)
Old 08-06-2024, 09:23 AM   #20
My props thank you!
Looking at the chart on Navionics I see nothing to hit there.
Is my chart wrong?
Are the markers misplaced?
Was it an unseen U-boat that was hit?
Old 08-06-2024, 12:21 PM   #21
DEJ
I think this is the cause. The OP posted the below message. Don't forget the prop/lower unit is about 18 to 24 inches below where transducers are typically located on the transom for depth readings.
The Following User Says Thank You to DEJ For This Useful Post:
ApS (09-12-2024)
Old 08-06-2024, 01:04 PM   #22
So how deep would the prop be in that circumstance?
Granted, I have not been there to run a depth sounder but the chart I am looking at shows 8'.
8' becomes 7' if the water is low.
The boat might draw 3'-4'.
Another 2' for the drive gets it to 5' or 6'.
Plow the boat and you get maybe 7'?
Old 08-06-2024, 01:55 PM   #23
DEJ
Go check the area out yourself when you get a chance. Some of those rocks at least to me seem allot closer to the surface that the chart says especially this time of year and later.
Old 08-06-2024, 02:46 PM   #24
I shall do so if you lend me a prop set...
Old 08-07-2024, 07:28 AM   #25
Bizer
Bizer's Avatar
... We were well inside the second red marker slightly to the right of center. Bizer, Navionics, Depth gauge all show safe water levels. ...
Not entirely correct. Bizer does show the southern half of the 6-pack in blue which indicates that much of that area is six feet or less. Back in 2010, Bizer did find one four-foot rock inside the 6-pack between the two red buoys. There is a "4" on Bizer's chart. When going northwest (with Long Island on your right), I tend to stay near the middle of the channel when the lake is low.
I shall be looking into this area during Bizer's annual survey of the lake in September.
I shall withhold comments about the accuracy of Navionics' depths.
Old 08-07-2024, 07:32 AM   #26
Can I get Bizer to run on my Garmin ECHOMAP HD2 53CV?
I am finding markers in the water that are not on my Navionics loaded Garmin screen.
Old 08-07-2024, 08:17 AM   #27
tummyman
I HATE my Navionics / Garmin Lake Vu software and long to be able to get BIZER back. Grmin does a terrible job with marker identification...so small that I can hardly see them. Terrible software for navigation. BIZER, we need you !!!!!!!
Old 08-07-2024, 08:35 AM   #28
RoBe
My props thank you!
Is my chart wrong?
There is a rock there, no doubt, based on my prop damage. I was heading toward the Bridge, there were two boats approaching, so I was to the right of the channel, well inside the red markers. I use Navionics on my chart which shows 8-9 ft. Just after the hit, I checked my depth finder, it read 6.5. Yes water levels are below average for this time of year. IÂ’ve been through there dozens of times over many years on the lake, completely caught by surprise. My bad, I guess, but this area needs markers adjusted IMO. Just be aware, it is a hazardous area inside those channel markers
Old 08-07-2024, 08:54 AM   #29
RoBe
I’m ready to switch to Bizer. Is a microSD data card available for a Lorrance plotter?
Thanks for all your great work charting the Lake. I’ve always had a Bizer paper map on board.
Old 08-07-2024, 09:30 AM   #30
MeredithMan
MeredithMan's Avatar
I don't go over that way at all, but if it is that bad inside the channel, I guess outside of it is much worse, (not navigable?)
Old 08-07-2024, 03:49 PM   #31
The Real BigGuy
So they installed markers!
DotRat (08-07-2024)
Old 09-12-2024, 08:47 AM   #32
Phantom
Phantom's Avatar
Just curious if anyone else has yet to find/ spot this rock ??
I have to be honest, since the original posting I have been reluctant to go through the six pack - an area that in the past I would use frequently.
Old 09-14-2024, 10:32 PM   #33
searay
Default Six Pack
If you are headed towards the Long Island bridge entering the six pack markers (red on your right) there is a very large rock slightly in between the first and second red marker. There are a few scrape marks on the rock. Stay in middle of channel. Don’t get pushed to that side.
searay is offline   Reply With Quote
The Following User Says Thank You to searay For This Useful Post:
Phantom (09-24-2024)
Old 09-15-2024, 04:08 AM   #34
One of those marks is ours' from many years ago-the only time we ever hit a rock in the lake. Who knew? You think if you are inside the buoys you are ok.
Old 09-16-2024, 08:10 AM   #35
winni83
We had company up for the weekend. One of our usual routes is to go through the Six Pack, under the Long Island Bridge, then around Long Island, etc. Based on these posts about the rock I was exceedingly careful going through the Six Pack, especially along the first and second red markers, keeping well into the center of the channel. Happy to report no hits from a rock and while I did not go looking for it, I did not see it. However at one point my depth gauge read 4.5 feet.
Old 09-18-2024, 02:48 PM   #36
Excalibur
I agree, I was going through on the jet ski slowly and noticed the yellowish color of a boulder or a (motel) , not much more than four feet under. If your on plane, no worries, but if your drafting deep it is definitely something on the right side you can bump this time of year.
Excalibur is offline   Reply With Quote
Old 09-25-2024, 09:31 AM   #37
RoBe
Ex, SeaRay,
Thanks for posting this and confirming that hazardous area. It was Aug 2 when I hit that spot. So from then on, I stay way left of those first two red markers, on plane, near the center of the channel. It creates a challenge for oncoming vessels for sure.
Old 09-28-2024, 03:08 PM   #38
Lake Fan
I kayaked over there with my son this morning. That rock pile is about 6 or 8 feet inside the markers. You can just make out one of the red spars over the stern of his boat.
His paddle is resting on the rock. It's maybe 3 feet under the surface at this lake level.
Lake Fan is offline   Reply With Quote
The Following 4 Users Say Thank You to Lake Fan For This Useful Post:
mcguirej (10-03-2024), Rocko (Yesterday), Senter Cove Guy (09-28-2024), Winilyme (09-28-2024)
Old 09-28-2024, 04:06 PM   #39
rick35
That's worth a call to Marine Patrol as that's a real danger. They should reposition the marker.
Old 09-28-2024, 07:10 PM   #40
Senter Cove Guy
Senter Cove Guy's Avatar
Default Marine Patrol Response
I would hope that Marine Patrol sees this as a serious problem, relocates 1 or more markers AND reports their response HERE. Thank you Marine Patrol.
Old 09-28-2024, 10:07 PM   #41
searay
Default Six Pack
Thanks for confirming this again. Markers need to be moved. Channel will be a little narrower but still plenty of room.
Old 09-28-2024, 11:44 PM   #42
Default Dynamite
In the good old days, Public Utilities Commission, before Marine Patrol and before DES, some hazards would be blown up and "debris" removed. Hole in the Wall is an example. Dredging the Weirs Channel to build Weirs Beach and harvesting rocks from the Witches instead of taking boulders from the shorelines, are, IMHO, good things to have been done. DES these days has no interest. I look at Florida where the Feds allow all sorts of dredging to make canals and to raise the land a couple of feet so homes will have canal shorefront and ground levels above high tides.
ApS (09-29-2024), TiltonBB (09-29-2024)
Old 09-29-2024, 04:18 AM   #43
We have a buoy near our house which is not even close to where it used to be when we first were in this location in 1985. I'm not sure what it is marking where it is now. When the MP person was looking at it, I told him this but his reply was it's where it should be according to GPS. So I guess it doesn't matter where the rocks are, as long as it's where it should be according to GPS. What year did they start using GPS, anybody know?
Old 09-29-2024, 04:47 AM   #44
We have a buoy near our house which is not even close to where it used to be when we first were in this location in 1985. ........ What year did they start using GPS, anybody know?
"Overview
The GPS project was started by the U.S. Department of Defense in 1973. The first prototype spacecraft was launched in 1978 and the full constellation of 24 satellites became operational in 1993."
www.wikipedia.org/wiki/Global_Positioning_System
Old 09-29-2024, 06:31 AM   #45
"Overview
Sorry, I meant when did they start using it on this lake?
Old 10-04-2024, 08:46 PM   #46
KPW
KPW's Avatar
Possibly 1993.
KPW is offline   Reply With Quote
Old Yesterday, 04:29 AM   #47
Originally Posted by KPW View Post
Possibly 1993.
That makes sense.
Old Yesterday, 06:33 AM   #48
The Real BigGuy
Default Six Pack
I wonder if Marine Patrol needs to do a reset of some of their GPS’s to account for satellite drift? My unit was off by about [emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]][emoji[emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]]] ft last year. When I investigated it turns out that that wasn’t unusual for my unit (Raymarine) and, unfortunately, it wasn’t something that was repairable according to the manufacturer.
Sent from my iPhone using ][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]]][emoji[emoji6][emoji[emoji6]]][emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]][emoji[emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6][emoji6]]]][emoji[emoji[emoji6][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6]]]][emoji[emoji6][emoji[emoji6][emoji6]]][emoji[emoji6][emoji[emoji6][emoji6]]]]]Winnipesaukee Forum mobile app
Old Yesterday, 06:37 AM   #49
The Real BigGuy
Default Six Pack
Anyone know why “emoji” stuff is showing up in my post? I’m definitely not using emojis
Sent from my iPhone using ][emoji6]][emoji6][emoji[emoji6]][emoji[emoji6]]]Winnipesaukee Forum mobile app
Old Yesterday, 07:45 AM   #50
I think you got attacked by the emoji army!!! Wow!
Old Yesterday, 07:46 AM   #51
TomC
TomC's Avatar
Emoji....!
Old Yesterday, 05:29 PM   #52
The Real BigGuy
Every time I look at it there are more “emoji”.
Old Yesterday, 05:33 PM   #53
The Real BigGuy
Default Six Pack
“Emoji” seems to only show up when I input numbers. I just updated IOS eighteen and this started.
Thread Tools
Display Modes
This page was generated in 0.38298 seconds
