07-28-2020, 05:57 AM | #1 |
leaking pontoon tube
I think one of my tubes on my triton is leaking , any thoughts on how to check.
07-28-2020, 06:37 AM | #2 |
Picture is worth a thousand words. I'd pull it immediately...you should be able to see the leak when it is to of the water and draining !
07-28-2020, 06:53 AM | #3 |
Pontoon tanks have drain plugs. Pull it, remove drain plug. If water comes out, its leaking. Could be a seam separation. Fill tank with compressed air to find leak. Have it repaired with aluminum weld. Good luck!
07-28-2020, 06:57 AM | #4 |
Call Irwin marine, they do pontoon repair.
Should be quick and easy, lot of leaking pontoons this year! |
07-28-2020, 08:20 AM | #5 |
Unless fairies came during the night and mounted 6 group 27 batteries on the starboard side, yep you do look to be sinking on that side.
Some toons have drains, some have bungs on top to pressurize, dealer will deal with it. Get it to your dealer asap before you become unusable. |
07-28-2020, 09:36 AM | #6 |
toon leak
Hello Rugman
yes your toon is leaking i had the same problem last year all pontoons will leak st some point due to rough water on winnie thats i was told mine was a weld on the planing finn where it welded to the toon they drained water re welded it then pressure checked it all set Easy fix Dave |
07-28-2020, 09:47 AM | #7 |
As other have said pull the boat, your toon is definately leaking..... most all the marina's on the lake can deal with this, although they may need to call in a welder to do the actual fix.....
As for the roughness of winni causing ab normal where and tear... That is bogus information..... Pontoons are prone to leaking, it happens.... Likely it was a defect from the manufacturing process, or something in the water was hit.....
07-28-2020, 10:05 AM | #8 |
"prone to leak"?
If 'toons are "prone to leak" why aren't they filled with foam or compartmented?
07-28-2020, 10:10 AM | #9 | |
Either way that looks a little scary, I would jump on that right away! As others have said, its likely not a major repair, so hopefully it wont set you back too much. Good Luck. |
07-28-2020, 10:14 AM | #10 | |
07-28-2020, 06:24 PM | #11 |
I know that look!
Last year East Coast Welding in Guilford fixed my issue last year. The amount of time that it will take to drain is surprising. |
07-28-2020, 11:54 PM | #12 |
Posts #4,6 and 7 lead me to believe that a leaking pontoon is not as unusual as might be the case with other types of boats. Two weeks ago, the folks working on my dock called a welder out from Gilford to fix their leaking pontoon on my beach. Unusual to me, so I give 4,6 &7 credibility. The earlier posts refer to a (singular) drain plug. If they are all compartmented, wouldn't there be several plugs, one for each compartment? Plugs on the bottom don't make sense to me, so, access from the top to pump out each compartment?).
07-29-2020, 04:59 AM | #13 |
The plugs on the bottom are so you can drain them. With plugs on the top you have to use some type of reducer on a shop vac to get the water out.
I have one pontoon that may have a quart of water in it by the end of the season and I jut take the plug out and let it drain. I am not sure if it is leaking or that is just condensation but it is a small enough amount that it doesn't matter. Someone above recommended East Coast Welding. I have also used East Coast Welding in Gilford and they do a great job. I know that they do a lot of aluminum welding. For many years they have been making a lot of the aluminum docks for Watermark. |
07-29-2020, 06:54 AM | #14 |
Thanks formal your input, I don't have a trailer, so I am going to call the dealer where I purchased the boat to pull out and get it looked at and repaired.
07-29-2020, 06:59 AM | #15 | |
Regarding leaks...I guess I should clarify, Pontoons don't leak because of waves or rough water...I would guess 90% of pontoon leaks are caused by mishandling during storage. I see many valet marina's set their pontoon boats right on the ground with nothing underneath them. This causes undue stress on the pontoons. The proper way is to put cribbing dunnage under the structural part of the pontoon (where the circular welds are and internal compartment supports are). Another issue I have seen is not draining the condensation that occurs before cold winter storage. Water seeps in corners and crevices of the welds and can pop the weld when frozen. The center pontoon on many of these tri-toons you see is completely open on the top and the inside is used for storage. Mine has a bilge pump in the center rear of the tube which should be run before navigating to remove any rain water that has collected. It's amazing how much water gets in there after a simple rain storm! I have never seen a pontoon boat sink...Have you? Dan
It's Always Sunny On Welch Island!! Last edited by ishoot308; 07-29-2020 at 11:35 AM. |
The Following 3 Users Say Thank You to ishoot308 For This Useful Post: | ||
07-30-2020, 08:54 AM | #16 | |
Because of this there are some places that will not rack store pontoons for Valet service. Harrilla landing by me is one of them.....
07-31-2020, 06:55 AM | #17 |
Had the same problem a couple of years ago......examined the pontoons visually in shallow water and found what was obviously forklift damage.
Tritoons are a little more challenging to lift......they have to reset the blades to fit.Anyway,it was a local marina and they owned the mistake and repaired it at no charge. |
Thread Tools | |
Display Modes | |
