Old 09-30-2021, 08:25 AM   #1
Default Mixing Stern Drive Lube viscosities ?
Just drained and refilled my Merc 4.3L sterndrive.
I bought 1 qt of Mercury SAE-90, but it was not enough. I can see this in the engine reservoir container, that it is about 4-6 oz, below the full line.
SAE90 is not cheap at $16 a quart. Question..... I have some 85W x 90 drive oil I used last year for a Outboard, can I add this to the current straight
SAE-90, without causing any issues ?
I'd buy another quart of SAE90 to add, but I'll be selling the boat in the Spring.
Thoughts?
Old 09-30-2021, 08:27 AM   #2
root1
'The wrong oil is better than no oil'
Old 09-30-2021, 10:27 AM   #3
Walmart.com says the Gilford Walmart has quarts of Quiksilver high performance sae-90 gear lube for $9.97/qt ..... and probably has Super Tech 80w-90sae marine gear lube for $6.28 .... and the out-drive will never know the difference!
5-stars, 10/20/2019: "Good price and I like the color of the oil (SuperTech). Easy to see if you have any water in your oil." ..... BigDaddy
Old 09-30-2021, 10:50 AM   #4
I dont mix different weights. I dont even like mixing same weights of different brands. Buy the other quart at $16 and save the remainder for next year..............
DotRat (09-30-2021)
Old 09-30-2021, 01:30 PM   #5
Yeah, don't do that, $16 is a lot cheaper than a lower end.
DotRat (09-30-2021)
Old 09-30-2021, 04:18 PM   #6
Just to repeat... 'I'll be selling the boat in the Spring'.
Only need about 6oz to fill reservoir to full level.
Thanks !
Old 09-30-2021, 04:40 PM   #7
It's $16 to do it right. Add it to the price when you sell it.
Old 09-30-2021, 06:29 PM   #8
Thanks !
That sounds a little sleazy to me....
SAB1 (09-30-2021)
Old 09-30-2021, 06:54 PM   #9
LakeDad
What would you do if you were keeping the boat?
Do the same for the next guy.
Its $16, Jeez…
I put a set of tires on a car once for my buyer.
$16?
Do you squeak when you walk?
BTW, thank you for the referral, Kevin!
LakeDad is offline   Reply With Quote
Old 09-30-2021, 07:28 PM   #10
$16 is the price of a 4 pack of micro brewed beer. Why screw the next guy. I’d be embarrassed to say that.
This page was generated in 0.24226 seconds
