Home | Forums | Gallery | Blogs | YouTube Channel | Classifieds | Calendar | Register | FAQ | Donate | Members List | Search | Today's Posts | Mark Forums Read |
Looking to get some opinions on a quote I received recently from a marina on Winni.
Got a quote to do the following: 1) Replace sterndrive pump impeller. 2) Replace sterndrive bellows. 3) Replace anodes. 4) Sand, prime and paint some areas of corrosion down near the skeg. Sterndrive is Volvo Penta DPS-B 2.32 and is on the boat. Quote is $800. I don't have a real good feel for this so any experienced opinions would be appreciated. Thanks Bob
#2 | |
Price seems low to me, maybe Mercrusier Bellows are more difficult than Volvo Penta. Just make sure your comfortable with the Marina doing the work. May be some other maintenance items to address with the drive pulled like the Gimbal Bearing. Again, I'm not familiar with Volvo but while it's apart do it all. |
The Following User Says Thank You to Formula260SS For This Useful Post: | ||
bobkatfly (05-13-2020) |
Do you have to replace the bellows every two years (recommended by the manufacturer) if you have a in and out service?
The Following User Says Thank You to WeLoveTheLake For This Useful Post: | ||
Sounds mostly routine, and reasonable price.. I'm aware of a boat that sunk in its slip because they didn't replace the bellows. Slow leak and the auto bilge pump kept up as long as the boat was being used and the battery charged. When use stopped for a few weeks, the battery went down and so did the boat. On fresh water, a lot of boats don't even have anodes. Is yours heavily worn because of salt water use? Some other factor?
Descant...
Most freshwater boats use anodes made from magnesium, not zinc. Galvanic corrosion occurs in fresh water as well as salt water. Stray electrical current from docks can also accelerate the corrosion. Woodsy
The Following User Says Thank You to Woodsy For This Useful Post: | ||
@Woodsy
Thanks for the clarification. When I asked the service manager about this a few years ago, he shrugged a little and said some people do, some people don't. We put it on the recommend list. If my dock did not have power, or on a trailer or valet, anodes, if you have them, should last longer than most other fixtures on the boat. So, the OP may or may not choose to replace depending on his boat's history. I have no idea, just bringing up the question. |
#7 | |
The boat is a 2012 Cobalt 210 that i bought in 2017 and I don't have any prior service history on it. It was in pretty good shape when I bought it so I've held off on service. I just think it's time to take care of the more common issues that could cause disasters as Descant described. I'll also have other items checked while drive is off. Thanks again everyone,
#8 | |
Thanks.
#9 | |
bobkatfly (05-14-2020) |
The impeller on a Volvo is not located in the stern drive rather is mounted off the crank pully of the engine.
Replacing one is far simpler and requires less time and disassembly as a Merc where the stern drive has to be drained and split. |
The Following 2 Users Say Thank You to MAXUM For This Useful Post: | ||
bobkatfly (05-14-2020), upthesaukee (05-13-2020) |
To clarify, Merc Bravo Drives are also engine driven. Alphas require splitting the drive. When doing a Bravo, I like to replace the assembly as a kit, not just the impeller.
The Following 2 Users Say Thank You to VitaBene For This Useful Post: | ||
bobkatfly (05-14-2020), CooperS7777 (05-16-2020) |
#12 | |
Thanks. Going to start a new post on my friends boat and hour meter if you care to comment.
#14 | |
Thread Tools | |
Display Modes | |
