09-06-2013, 10:50 AM | #1 |
Smoking fireplace
Last fall we had the chimney cleaned and a cap installed at our island cottage. Ever since, the fireplace has been smoking like crazy. We called the chimney guy who said neither the cap nor cleaning should make a big difference in how the fireplace draws. It always smoked a little, but now it's terrible.
Looking on the internet, I see something called a baffled chimney cap. Does anybody have any experience with that? Any other suggestions? Thanks! |
09-06-2013, 10:55 AM | #2 |
Open a window and see if that stops the smoking, you may not have enough make up air to get a good draft. If that doesn't help, pull the cap off and see if that helps. Good luck.
welch100 (09-07-2013) |
09-06-2013, 12:11 PM | #3 |
If you didn't have a cap before then I would suspect that as the culprit.I would do as ITD suggested.
SIKSUKR |
The Following User Says Thank You to SIKSUKR For This Useful Post: | ||
09-06-2013, 02:23 PM | #4 |
Smoking fireplace
First, check to see that the damper is open all the way. If it is, then try the window trick. If this doesn't help, it could be that the cap is too close to the opening of the chimney and has reduced the amount of opening for exhaust to a space smaller than necessary.
Also, if this is a situation you are experiencing just now it could be that you are not building a hot enough fire to really heat up the chimney and get a good draft going. Sometimes, in the early fall, people build a small fire to "just take the edge off" and this creates a problem in that the products of combustion basically, creosote) aren't fully exhausted and precipitate out onto the walls of the chimney. Then, a little later, when you build a much more robust fire you run the risk of igniting these precipitated by-products and experiencing a chimney fire (not fun). I would check the draft as a first line of diagnosis. |
The Following 2 Users Say Thank You to camp guy For This Useful Post: | ||
GsChinadoll (09-06-2013), welch100 (09-07-2013) |
09-06-2013, 08:06 PM | #5 |
Tell the firm that put the cap on to get their collective A$$$'s down there and solve the problem. Be nice, but firm! It was OK before they did their work, and now it ain't.
09-07-2013, 07:59 PM | #6 | |
Spark-Screen Involved?
If this is the case, "someone" will need to inspect the cap (and "spark screen") on the rooftop. I'm not saying to throw away the "spark screen". If that's not the problem, you might block the cap on the side that faces the strongest winds. Wind direction and shape of the roof can play havoc. We get smoke with easterlies, but no other winds. Last edited by ApS; 09-08-2013 at 12:43 PM. |
09-07-2013, 08:47 PM | #7 |
Being that the chimney was just cleaned also, I would suspect the damper was adjusted during the cleaning. Then closed, or set to where they thought it was, when the job was done.
That would my first place to check. |
09-08-2013, 06:57 AM | #8 |
We have a smoky fireplace in a fairly new building. We have to crack a window or door to stay in the place. It is very disappointed. The mason who is one of the best in the area, has been back and back, even put a new (I don't know what you call it) but it's another rectangular hole and it still smokes. I guess we just live with it.
09-08-2013, 07:25 AM | #9 |
Get rid of the cap
Had same issue. Lose the cap AND if it still smokes have the mason add more length to the chimney and it will help with the draw.
09-10-2013, 03:30 PM | #10 |
Problem solved!
Thanks to everybody for the good suggestions! We tried them all, starting with the easiest and working our way through. Finally climbed on top of the roof and took off the chimney cap. Now the fireplace works great! The new cap significantly reduced the size of the chimney opening; maybe that was the problem. Anyway, we are delighted to have a working fireplace again.
09-10-2013, 04:10 PM | #11 |
Lucky you, we don't have a cap. Happy burning!!
Thread Tools | |
Display Modes | |
