Home Forums Gallery YouTube Channel Classifieds Links Calendar Register FAQDonate Members List Search Today's Posts Mark Forums Read
Old 07-14-2018, 10:34 AM   #1
Garcia
Default Moss on roof
Anyone have experience getting rid of moss on a shingled roof? I’ve heard about products like Wet & Forget or a mixture of bleach and water but am wondering how they work before I go through the trouble of applying. I get the pine needles off with a stiff broom but the moss is pretty stubborn.
Any ideas appreciated - the roof has a few more years of life before it gets replaced with a metal one which will lessen the moss and pine needle problem.
Old 07-14-2018, 10:56 AM   #2
Wet and Forget works as good as everybody says.
The Following 2 Users Say Thank You to thinkxingu For This Useful Post:
Descant (07-16-2018), Garcia (07-14-2018)
Old 07-14-2018, 11:18 AM   #3
moose tracks
moose tracks's Avatar
Yes, Wet and Forget will get rid of the moss but it will take a few months.
Moose Tracks
The Following User Says Thank You to moose tracks For This Useful Post:
Garcia (07-14-2018)
Old 07-14-2018, 11:33 AM   #4
The Real BigGuy
Oxyclean works quicker that W&F. Mix as directed on box. Use garden type sprayer and apply when it is sunny for a day or two. Because it is an oxygen bleach not a chlorine bleach it won’t harm roof, shrubs, etc. and runoff won’t damage lake.
The Following 3 Users Say Thank You to The Real BigGuy For This Useful Post:
Descant (07-16-2018), FlyingScot (07-14-2018), Garcia (07-15-2018)
Old 07-15-2018, 01:15 PM   #5
Wet & Forget.
Our camp on Welch is shaded so 7 years ago there was some moss and lichen starting. One Wet & Forget application and all was gone after several weeks. It has taken 7 years for just a few small patches of lichen to reappear. So I recently gave the roof another application and in a while it will be clear again.
Garcia (07-15-2018)
Old 07-15-2018, 07:48 PM   #6
Default Wet and Forget fan here too
I’ve used Wet and Forget on my roof and it cleared up in a matter of weeks.
Garcia (07-15-2018)
Old 07-15-2018, 10:07 PM   #7
FlyingScot
Just curious on the Wet and Forget vs Oxyclean question--Wet and Forget obviously has a big following, but I saw from The Real Big Guy that Oxyclean was quicker on roof and better for the nearby plants and lake. Have any other Wet and Forget users tried Oxyclean?
Old 07-16-2018, 05:33 AM   #8
I posted about a year ago asking for suggestions and both options came up. I went with W&F because I happened to be at Walmart just after reading they sold it there. Since it's in the shade and I couldn't see it, my shed roof had gone way too far, so I thought I'd have to use a few applications, but one treatment wiped everything out and with some rain, my roof is now completely clear for the second year. I still have 3/4 of a bottle, which I just took home to treat a small eave on my home. (I understand the second-to-last sentence is an abomination)
Old 07-31-2018, 10:16 AM   #9
MeEscape
Am I correct in understanding that you just used Oxiclean mixed with water? No bleach or anything else. Do you need to sweep it clean or can you do nothing, or just rinse with a hose?
MeEscape is offline   Reply With Quote
Old 07-31-2018, 12:44 PM   #10
The Real BigGuy
Oxyclean is bleach, only oxygen bleach instead of chlorine bleach. Yes, just mix it with water per the directions on the container. The key is to spray it on during growing time (warm moist weather with lots of sun). Once it is dead you may be able to just hose it off. I used a combination of hose & a little vrooming.
MeEscape (07-31-2018)
Old 07-31-2018, 12:48 PM   #11
The Real BigGuy
Maybe a chemist out there can discuss this but, I would not mix Oxyclean with chlorine bleach because I don’t know if there would be a chemical reaction that would liberate chlorine gas.
Old 08-08-2018, 08:57 AM   #12
Per Oxyclean website:
OxiClean™ Versatile Stain Remover should not be mixed with chlorine bleach or any other household chemicals.
Old 10-18-2018, 11:03 AM   #13
Dave M
Default Wet & Forget
I hit the roof with W&F about 3 weeks ago. The moss has turned brown. Is this the normal process. Do I need to hit it again or scrub with broom or neither.
Thanks Dave M
Old 10-18-2018, 11:21 AM   #14
Woody38
You don't need to do anything further except let the Wet and Forget do it's thing. This is not immediate and also is determined by the amount of moss present Next spring you should see a difference. I apply bleach (the blue container) diluted somewhat. Later I apply the Wet and Forget. I have not had to reapply for 2 years so far.
Good luck.
________________________________________
am a retired workaholic and continuing aquaholic
Old 10-18-2018, 05:10 PM   #15
RUGMAN
I put strips of zinc strips along the ridge and it has worked great, No more moss.
The Following User Says Thank You to RUGMAN For This Useful Post:
Rusty (10-19-2018)
Old 10-18-2018, 07:20 PM   #16
Woody38
I have thought about this solution for some time. How are the zinc strips attached and how visible are they. Would the strips be unsightly from the street.
___________________________________________
Old 10-18-2018, 09:07 PM   #17
Rusty
Sometimes I wonder what some people look at when they drive up to their home, the moss doesn't all of sudden appear on their roof. Don't they see how many trees are keeping their home from the sun and this allows the dampness to feed the moss?
It would be better to work on some preventative stratagy than to wonder how they can remove the moss after it damages the roof.
Just my observation of this thread and not meant to insult anyone.
Old 10-19-2018, 06:55 AM   #18
I agree with you, Rusty, But on the lake, you can only cut so many trees. Lots of trees also make for lots more mosquitos and bugs. I believe that in the future a lot of homes are going to end up with mold problems from the dampness.
Rusty (10-19-2018)
Old 10-19-2018, 07:20 AM   #19
Rusty
They might be "unsightly" to some people (but I doubt it), however moss is unsightly to everyone.
Zinc strips along the ridge vent when new shingles are put on are highly reccomended on roofs that get little sun.
Old 10-19-2018, 09:06 PM   #20
Woody38
Thanks Rusty. Most likely my wife will say it is unsightly. But, worth a try.
Old 10-20-2018, 04:49 AM   #21
How come we are agreeing so much lately, Rusty?
Rusty (10-20-2018)
Old 10-22-2018, 09:25 AM   #22
Wet it and forget it, is the solution. If you apply it inline with the directions, the moss will die with in a few weeks... I have not had any issues with plants, grass etc. dying off after it washes off the roof with rain.
It has taken me almost 10 years to go through a 64 once bottle... I have used it on Decks and roof.... and apply it say every 3 or four years...
Old 10-22-2018, 01:37 PM   #23
W&F worked awesome for me last year, but this season was so moist it came back. Zinc strip going up as I type.
Old 10-22-2018, 03:50 PM   #24
The next time the roof is replaced I plan to do the same thing.... at least on the shady side of the roof........
Old 10-23-2018, 06:04 PM   #25
RUGMAN
I tucked the strips underneath the top course of shingles and you really have to look to see them, I think it is a long lasting solution, no need to climb back on the roof to spray wet and forget on roof.
Old 10-24-2018, 03:50 AM   #26
Question Will It Be Zinc or Pine-Needle "Chemistry"?
We have a shingle roof, and for 50+ years, no roof issues.
Out of concern for an "unsightly" layer of pine needles, a family member asked about sweeping them off.
"Knock yourself out", I said.
So for about ten years, the pine needles were regularly swept off.
Then I was asked, "Should I sweep the moss off the roof?
Well, now the moss has grown over the edge of the roof, and caused what appears to be likely damage to the facia ["facing" boards]. (At 25 feet off the ground, something I'm not going to repair myself).
Can I make a case that this relatively new moss growth was inhibited by a thin—but constantly-changing—layer of pine needles?
.Sailing—Good for you and good for the world...
Old 01-28-2019, 06:56 PM   #27
WinniWorkers
Default Moss Removal/Roof Washing
Hi Guys, you can use bleach or oxi-clean or wet and forget. I prefer using oxi-clean when i am working on the water because it breaks down into soda ash and hydrogen peroxide, which are both naturally occurring. Bleach gets a bad rap but it actually breaks down into salt and water. I avoid it because most bleaches contain surficants that can harm the environment. When applying you should do so on a sunny day. You first get up and brush off any heavy debris with a deck broom if you can. Although it isn't necessary. Next you, apply whatever solution you are using and let it dry. You then make a second application and you are done. It is wise to bag off gutter downspouts so as not to damage your shrubs or lawn. You can use the low soaping settings on a pressure washer to apply but DO NOT try to pressure wash debris off your roof as you will damage it.
https://www.facebook.com/FairTradeHomeSolutions/
My company services the islands and surrounding towns and if you don't want to do the project yourself feel free to give us a call at 603-757-6618.
Best,
Brandon
Fair Trade Home Solutions
WinniWorkers is offline   Reply With Quote
Old 01-28-2019, 07:43 PM   #28
Rusty
Best,
Brandon
Glad to see one of your workers picked a good beer to drink while working on a roof. Saw this on your Facebook photos.
Old 02-05-2019, 01:42 PM   #29
WinniWorkers
That was a weekend job where I was working on a fellow roofers house for free and had time to take pictures. I actually don’t drink at all and my work crews are all professionals and hard working people. Any given crew that I provide would have at least 30 years of experience. My family also has a place on the lake and have worked in the trade for years and care very much about our work as we are part of the winnipesaukee community. Thank you for pointing out the photo.
The Following User Says Thank You to WinniWorkers For This Useful Post:
Rusty (02-05-2019)
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
This page was generated in 0.17897 seconds
