Old 05-19-2024, 04:22 PM   #1
Default Grass Issue?
I have an issue with a section of my grass, after this past winter season.
The grass in question was fine last Fall, no issues. The patch of grass in question, is roughly 16x10, and appears spongy in some places when walking on.
There are no holes or tunnels on the surface, at first I thought it may be grubs,
or maybe just a nitrogen deficiency, what's your thoughts and opinions.
Thanks.
bigdog is online now   Reply With Quote
Old 05-19-2024, 05:06 PM   #2
Bear Islander
Bear Islander's Avatar
The test for grubs is simple. Pour soapy water on the area. If there are grubs, they will surface in about 15 minutes.
The Following 3 Users Say Thank You to Bear Islander For This Useful Post:
bigdog (05-19-2024), FlyingScot (05-29-2024), mhtranger (05-26-2024)
Old 05-19-2024, 05:36 PM   #3
SteveO123
Classic grub symptoms..
Old 05-19-2024, 06:05 PM   #4
L3Gman
https://www.truesdalelandscaping.com...mes-snow-mold/
Hello, a possibility of this might be from snow mold. This link shows some damage from it.
L3Gman is offline   Reply With Quote
Old 05-19-2024, 07:30 PM   #5
John Mercier
When was the last time you dethatched it?
Old 05-20-2024, 01:08 PM   #6
Just dethatched this Spring.
Old 05-20-2024, 03:23 PM   #7
John Mercier
It is grub season...
Can you use the soap and water technique?
It won't kill them, but it should force them to the surface for verification.
Go beyond the edges of the brown patch.
Old 05-20-2024, 07:08 PM   #8
Iíll go with this. Especially if that area held a little water and froze. I donít see any mole tunnels in that area if there were grubs the moles would have been after them.
Old 05-20-2024, 08:44 PM   #9
John Mercier
It is possible, but snow mold usually has a thatch problem attached to it.
Old 05-19-2024, 07:43 PM   #10
The Real BigGuy
I (my lawn)had grubs last year. Was told by the lawn & garden center to treat from late spring to fall because the grubs breed during winter and new batch start activity in spring. They said if you treat before they start to feed you are wasting your time & money.
A neighbor had a patch of real spongie lawn and it turned out to be a major ant colony.
Old 05-20-2024, 04:38 PM   #11
TheTimeTraveler
Thanks.
Be careful. When the word gets out that you have grubs you will suddenly
have a lot of skunks in your yard tearing up the grass for you...
Old 05-21-2024, 04:58 PM   #12
TheProfessor
Years ago. I took a section of my lawn to the UNH Extension school in Durham.
I was directed to one office/professor.
And he imediately promptly answered my question.
Had no appointment. Just walked in.
Old 05-21-2024, 06:36 PM   #13
Default Unh
^^^^^ Yes this ^^^^^^^^
I believe UNH will pretty much test your soil, analyze your grass all for free!Ö.or at least it wasÖ
Old 05-21-2024, 06:58 PM   #14
feb
Default UNH Testing
I had my lawn tested this year. Took about 4 weeks after sending in soil sample. Cost $20. My lawn has been struggling for a few years and they said I need Potassium. I added some a few weeks ago and its already recovering. Best $20 I've spent.
https://extension.unh.edu/agricultur...sting-services
Old 05-22-2024, 08:24 PM   #15
KPW
KPW's Avatar
Grow flowers and bushes.
KPW is offline   Reply With Quote
Old 05-25-2024, 10:59 AM   #16
Thanks.
Circling back from my original Post.
I put down some Grubex, and many grubs came to the surface and died !
Problem solved !
However now, I'm left with a huge brown spot in the lawn, is it dead, and what can I do to bring back that lawn ?
Old 05-25-2024, 03:44 PM   #17
Resident 2B
Resident 2B's Avatar
Problem solved !
Buy sod from a good local gardening center. Dig up or turn in the old lawn, wet it good, then install the sod. Make sure you Grubex around the green grass close to the brown grass to eliminate all the grubs.
Old 05-25-2024, 04:12 PM   #18
John Mercier
Problem solved !
Rake. Put down repair grass of whatever brand you use - usually has a mix of annual and perennial seed. Keep most until the first sign of green. Then water deeply when we don't have a lot of rain.
The annual should come up rather quickly, and the perennial will fill in over time. Contractor mixes are designed like this to get a quick lawn into place for a sale; but generally only come in large quantities - too much for such a small repair.
Old 05-29-2024, 09:17 AM   #19
The Real BigGuy
Problem solved !
Yes it is dead. Grubs eat the roots of the grass. I would go with John’s option.
Thread Tools
Display Modes
This page was generated in 0.25327 seconds
