07-04-2016, 03:02 PM | #1 |
Help with steering noise
Hi! On our new boat we have the Seastar hydraulic steering system--besides the initial tap when turning from one side to the other, should there be any other noise? I'm getting clunks as I turn the wheel and am not convinced I should be. It's a Mercury 150 4-stroke, BTW.
Thanks! Sent from my XT1528 using Tapatalk |
07-04-2016, 04:01 PM | #2 |
Initial tap?
Why would there be an initial tap? I'm not sure what that means. A hesitation? Hydraulic steering should be smooth all the way left to right and back. Perhaps after a little use, you have a bubble in the system and it needs to be bled? In a former boat I had to add fluid every spring. Nobody ever saw a drop lost into the bilge or around fittings, etc. (Scotch is aged in a full barrel. When you tap it six years later, some is missing. This is known as the Angel's Share.) You may have an angel in the hydraulic system.
07-04-2016, 04:47 PM | #3 | |
07-04-2016, 05:24 PM | #4 |
I have the same system as you (last two boats actually) and it's always been very smooth with no clunking or other sounds. As stated above, possibly air in the system. Have the dealer check it out as it is a new boat.
07-04-2016, 05:49 PM | #5 |
That little bit of play is called a hysteresis (whew, big word, Google it if you don't believe me). It's normal and the natural torque of the prop spinning may make a difference in left vs. right turns as well. Lot's of variables involved. All this being said, if your wheel turns free for much more than a quarter turn you could have another problem.
07-04-2016, 09:40 PM | #6 |
Big word notwithstanding, it should be smooth throughout the range or rotation.
07-05-2016, 05:01 AM | #7 |
We have Seastar on the new Eastern with a 115 Yamaha; absolutely smooth lock to lock. As noted, you could have air in the lines.
At speed with the wheel stationary the system acts to hold the steering fixed so that prop torque will not turn the steering if you take your hands off the wheel. Like a hydraulic clutch. The wheel has to be turned a slight distance either way to release the clutch effect however the transition should be smooth. (Yes hysteresis is a proper term). |
07-05-2016, 08:02 AM | #8 |
Thanks, everyone--one other question: since I'm feeling it in the steering wheel, what might be the problem?
07-05-2016, 03:27 PM | #9 |
As others have said it sounds like air in the steering system.... Bring it to the dealer and have them bleed out the system.....
07-20-2016, 02:21 PM | #10 |
So the dealer replaced the helm, but the noise/feeling is still there (albeit maybe a little better). It was mentioned that it might take time for the air to move to where it can be bled completely, but now I'm not sure what to do. Thoughts? Is there anyone in the north of the lake that has more experience with boats that might be willing to check it out and gimme their thoughts?
07-21-2016, 12:31 AM | #11 |
Hi thinkxingu, I'll take a guess that won't cost much but might be worth a try.
Without knowing exactly what the engine of your boat looks like here is where I would go next. You said you had a mercury 150, I'm familiar with that family of outboard motors, most of these outboard motors are all the same with regard to how the steering works and it's been pretty much the same design for many years. Regardless of what kind of system the steering wheel is connected to the heart of steering takes place at the "Swivel Bracket" on the engine assembly. See if you can locate these two grease fittings on the swivel bracket and lubricate them. They are somewhat hidden from view when the entire engine is assembled. Obviously these are just "part images" but will give you a clue where to look. Often folks only lubricate the one in the first image hoping it will correct steering problems like noise and binding problems. The clunking noise could be from something binding. Despite how close it is to the steering cables or hydraulic lines that connect to the steering wheel it does nothing to lubricate the steering. It's actually the lubrication point for tilting the engine. The one you really want to find is in the second image, that is the one that might? maybe? could? be the problem. If the steering is binding at this location you are going to feel it in the steering wheel. (You might have to turn the motor all the way to one side or the other to find / see this one) On a newer boat I kinda doubt that this would the problem but might be worth a try. (A lot of folks never grease this for years with no problems) The thing to look out for is even if it does not solve the problem ..... see if the problem changes its behavior ......... . Often grease will dampen or quiet a clunking noise for a while until it needs more .... maybe giving you a new clue what to look for next. Good luck #1 #2 Approximately where to look for these grease fittings. Last edited by Top-Water; 07-21-2016 at 01:20 AM. |
The Following User Says Thank You to Top-Water For This Useful Post: | ||
ApS (07-21-2016) |
07-21-2016, 05:45 AM | #12 | |
07-22-2016, 04:05 PM | #13 |
Since this is a hydraulic system, there's a steering ram connected to the engine to turn it correct? If they've replaced the helm and the issue is still present perhaps the problem is in the ram at the engine. The hydraulic fluid could transmit any sudden motion or vibration through the lines to the helm where you feel it. Just a thought, good luck.
