Old 07-25-2019, 11:49 AM   #1
IslandRadio
IslandRadio's Avatar
Question Need insulation removed from a basement area (floor insulation)
Hi !
I need to have the insulation of a floor area completely removed.
This is a botched floor insulation homeowner job from the previous owner. The insulation was installed with the vapor barrier DOWN - and then plastic installed over that. So the insulation is damaged due to sustained moisture due to condensation within the insulation.
It has to be removed and properly disposed of.
This is in Tuftonboro.
Anyone know of a reasonable contractor who could do this. At some point, after some serious renos are completed, the floor will need to be re-insulated.
But for now, the old insulation needs to be removed.
Thanks and Regards, Steve
IslandRadio is offline   Reply With Quote
Old 07-25-2019, 05:59 PM   #2
djwade4
Originally Posted by IslandRadio View Post
Hi !
Call me. Doug wade bluebird construction. I have some questions 603-770-3677
djwade4 is offline   Reply With Quote
Old 07-26-2019, 07:02 AM   #3
Question A question...
The insulation installation is "botched"?
Can you provide a picture of what you're seeing?
Old 07-26-2019, 10:22 AM   #4
Besides degradation of the insulation due to having the vapor barrier on the cold side (in winter), resulting in condensation of interior moisture diffusing through the insulation to the cold surfaces, I have to wonder if long-term accumulation of moisture has damaged the bottoms of the floor joists. Wetness held there by that plastic vapor barrier won't dry to the exterior easily.
As part of your later renovation efforts, and assuming you have a crawl space under the living space, you might think about enclosing that crawl space, eliminating any air leaks into it, insulating its walls, and having a sturdy vapor barrier over the ground. A lot of good information on all this can be found on greenbuildingadvisor.com.
IslandRadio (07-27-2019)
Old 07-27-2019, 07:28 AM   #5
The best insulation for a basement is spray foam.
Old 07-27-2019, 03:17 PM   #6
IslandRadio
So far, I have not observed any degradation of the joists themselves. The home inspector also did not flag any damaged joists.
However, yes, job 1 here is to get this crawl space (about 5 feet high) sealed up properly (after the old insulation has been removed of course).
Old 07-27-2019, 03:22 PM   #7
IslandRadio
The insulation for the floors is installed with the vapor barrier AWAY FROM the (warm, in the winter) living space.
So, during the cold months (the people lived here year round), the warm, relatively moist air from the living space will work its way through the insulation until the dew point is reached, at which time the vapor will condense and form water dropletts.
And then the condensed water is more or less trapped there due to the vapor barrier.
It appears to me as if the house was built with uninsulated floors, and then the homeowners installed insulation after the fact.
This page was generated in 0.27798 seconds
