Old 03-16-2019, 05:05 PM   #1
Boomer
Default Drywall repair
Hi All, I have a hole repair project in my Meredith home due to a change in the location of a thermostat. Can anyone recommend someone who does that sort of thing?
Boomer is offline   Reply With Quote
Old 03-17-2019, 06:33 AM   #2
The Real BigGuy
Not hard to do yourself if you have a leftover piece of drywall.
Square the hole.
Cut a piece of drywall the same size as the squared whole.
Cut 2 pieces of 1x or furring 4 inches longer than the side of the square.
Center the wood pieces to the inside of the drywall at the top and bottom of the square hole using a drywall screw at each end.
Place the new piece of drywall in the hole over the wood and attach with a drywall screw in each corner.
Put drywall tape over the seams and spread drywall mud (you can get a small tub of pre-mixed at Lowe’s or Home Depot).
Sand smooth.
Repeat mudding/sanding feathering the mud out till you can’t see the seams or the mud marks (this is the time consuming part.)
For a thermostat hole should take a beginner less than an hour if they have the materials.
Boomer (03-17-2019)
Old 03-17-2019, 06:36 AM   #3
The Real BigGuy
Time doesn’t include mudding/sanding process. (Sorry, forgot to add this)
Boomer (03-17-2019)
Old 03-17-2019, 06:40 AM   #4
Hang a picture over the hole.
Boomer (03-17-2019)
Old 03-17-2019, 11:48 AM   #5
Flylady
Default Diy
You tube has many videos of repairing drywall yourself.
Flylady is offline   Reply With Quote
The Following User Says Thank You to Flylady For This Useful Post:
Top-Water (03-17-2019)
Old 03-17-2019, 02:29 PM   #6
Top-Water
Exactly
The Following User Says Thank You to Top-Water For This Useful Post:
Boomer (03-17-2019)
Old 03-17-2019, 09:27 PM   #7
Woody38
Take a look at Ron Hazeltons site.
Search drywall repair.
www.ronhazelton.com
______________________________________
Old 03-23-2019, 10:17 AM   #8
welch-time
welch-time's Avatar
Google "California Patch". I've been meaning to try this myself.
welch-time is offline   Reply With Quote
The Following User Says Thank You to welch-time For This Useful Post:
Top-Water (03-23-2019)
Old 03-23-2019, 12:10 PM   #9
Top-Water
Excellent video .......... Thankyou
Thread Tools
Display Modes
This page was generated in 0.21954 seconds
