Old 09-09-2019, 11:07 AM   #1
SailinAway
Default Need programmed car key
(1) What's the most affordable place in the area to get a spare key made and programmed?
(2) For a spare key to keep in my wallet, is it possible to get just the key, without the heavy fob?
This is my first programmable key. I like to have a total of 4 keys in various places. Looks like that's not possible given the cost of this key. I'm especially worried about losing my key far from home. How many keys do you have, and where do you keep them in case you lose your main key?
Old 09-09-2019, 11:11 AM   #2
Phantom
Phantom's Avatar
Answer to Question #2 -- I have the one I use daily & my second (spare) is stored away in my Safe Deposit Box (my wife's pocketbook)
Old 09-09-2019, 11:34 AM   #3
the keys with the FOB have a chip in them that speaks to the vehicle computers to allow it to turn on. Unless the vehicle has a valet type key option, it will need to have the FOB head on it. Most FOBs have a key in the back of them that you can pull out and use incase the FOB battery dies, in this case you can put that key in the wallet
Old 09-09-2019, 02:58 PM   #4
Outdoorsman
I have seen signs at Do It Best Hardware stores that say they can make programmed keys. I have never had one made so I am not sure price. It looks like Rands Hardware in Plymouth is a Do It Best Hardware Store, might be worth a call.
As a side note, if you ever lose your key and you are far from home, the local dealership should be able to help you out by using the VIN and having proper ID.
I think you are confusing/mixing a (key + a FOB) and a "keyless" FOB.
A keyless FOB has a key in it in case the battery dies, the other one..... just use the key
Old 09-09-2019, 08:33 PM   #5
TheTimeTraveler
This is all about the automobile manufacturers controlling the keys for all the vehicles you now buy. Big money @ $200 or $300 per FOB.
Remember the days you could go to your local Locksmith and they'd make as many keys as you want for $5 each (or less) ?
It's all about control and huge profit.
Old 09-09-2019, 08:42 PM   #6
Wifi-1
Wifi-1's Avatar
Gone are the days a parking attendant or younger family member can just have them duplicated
Old 09-09-2019, 09:38 PM   #7
Question Be a Clumsy Driver—Get Rewarded?
This is all about the automobile manufacturers controlling the keys for all the vehicles you now buy. Big money @ $200 or $300 per FOB. Remember the days you could go to your local Locksmith and they'd make as many keys as you want for $5 each (or less) ? It's all about control and huge profit.
Back when these were a new "thing", I remember a Toyota owner having to pay four-figures for a replacement. (!) Then it turned out his car insurance would pay for it....
Then I read that Toyota braqged that they had never had to replace the battery pack in their Prius model.
The explanation later came out that their instruction book said to replace the battery pack after collisions—however slight the collision.
Guess who's paid for all those batteries?
.Sailing—Good for you and good for the world...
...and you won't stink...
Old 09-11-2019, 10:58 AM   #8
www.napaonline.com/en/p/NSO101311 ..... $85.04-each key ...... maybe this will help?
For $1.50, you know I recently got a spare key made at Walmart which I keep in my wallet, in case I lock the regular, old standard wafer tumbler key inside the car. ..... high tech car keys ..... ...... tanks, but no thanks!
And, this $1.50 ignition key works perfectly to unlock the door, and start the ignition ....... a nickel plated, brass, double sided car key similar to the 1980's style car key ..... it is thin enough to keep a spare in your wallet ...... unlike the big fat hi-tech keys
Down & out, livn that Walmart side of the lake!
Old 09-11-2019, 08:24 PM   #9
TheProfessor
What is the make model and year of vehicle?
Makes a world of difference.
Some chip keys - one can purchase a blank and have hardware store or dealership cut. Usually at no charge.
Then you can program extra key yourself.
Some chip keys can only be programmed at dealership. You do not have to purchase the key at the dealership. Although you usually need a factory OEM key.
MBNeckguy (10-11-2019)
Old 09-11-2019, 10:33 PM   #10
TheTimeTraveler
If you have the FCC ID # of the original key FOB then you can usually pick one up off of eBay for a fractional of the price of the New Car Dealership.
Be sure you are getting an OEM Key FOB and be sure to replace the small button battery prior to having it programmed.
Old 09-19-2019, 01:32 PM   #11
rander7823
rander7823's Avatar
Default I have used these guys
I have replaced Dodge, Nissan, Honda and Ford key fobs at this place. all way cheaper than the dealer and with easy to follow instructions to program
https://www.keyless-remotes.com/
rander7823 is offline   Reply With Quote
Old 09-23-2019, 11:29 AM   #12
Default Pros and Cons
We drive Ford products, all with keyless entry, so we can just leave the keys in the car.
C:Without the key, you can't flash the lights to find your car in a large parking lot.
P: A pick pocket / purse grabber, without the key, can't flash the lights and drive away with your car.
A friend traveling in NYC had occasion to be treated by an EMT who was fascinated that people in NH don't lock their house. If you don't lock the house, why lock the car?
Old 10-01-2019, 02:38 PM   #13
TheProfessor
Well . . . what was the solution ?
Old 10-11-2019, 01:48 PM   #14
ghfromaltonbay
Default Keyless-remotes.com
The 2 keyless remotes for my 2010 Malibu lasted until this past spring & summer. The diagnosis was broken contacts inside on both. I lucked out at this website recently too as the A.C. Delco remotes for my vehicle were on sale from $72 marked down to $19 each. (I am sounding like FLL). Cantin Chevrolet programmed the replacement for $30! I had kept one of the old ones as just a spare key, but decided to order a 2nd at that price. I have to have that one programmed, but will wait till I get back to NH. I had priced the remotes at my local Chevy dealer here in NJ and was quoted $140/remote + $60 to program + 7% sales tax! I can wait till my Feb. trip to NH at those prices to have it done at Cantin.
Thread Tools
Display Modes
HTML code is Off
Copyright ©2000 - 2019, vBulletin Solutions Inc.
This page was generated in 0.13502 seconds
