Does anyone know what the lake temp. is today? I checked the link, but there are no postings for June. Also, the pine pollen started in Southern NH today. How bad is it at the lake? Are the sand bars yellowed (by pollen that is
Education is hanging around 'til you've caught on - Frost |
The lake temp is online in real-time.
Check the Lake Winnipesaukee WeatherCam, near the bottom of the page (at www.blackcatnh.com) and also the Bear Island Cam. It actually made it into the 60s today at the surface. Has yet to get out of the 50s at 10 feet down. Running below normal this year, so far. The high humidity usually makes it rise quickly, though. I would expect 70 at the surface by Monday. Doesn't really matter if it's chilly... if you work up a sweat for a few minutes first and then get in, you won't care! |
The water should be warming up big time and fast.
I was in the water for 30minutes yesterday putter'n on boats, and it is cold but doable. Hey, after 5minutes, you get numb and don't feel the cold too bad.
At the WeatherCam the surface temp is about the same as it was yesterday but the temp at 10 feet down has risen to match it. Today's heat helped to circulate yesterday's heat down. Tomorrow's will probably bring the surface to around 68 while the depth remains cooler.
I noticed a difference in water temp today versus yesterday...musta been a 10 degree swing. Gotta love it.
Riding home today down rt109 I noticed the pine pollen building on the surface of the lake in the coves. The waves were pushing it into the shore. I also noticed it getting heavier on the car.
My mom asked about the yellow pollen yesterday morning, within an hour I saw it on the lake. The pine trees around the lakefront are loaded. The heat will get us all.
Saturday between Glendale and Braun Bay I showed 63 degrees.Sunday I launched at Glendale at 3pm and showed 66.In the Broads the temp increased to 69 and right back to 66 nearing Glendale.This was a surface temp measured on the bottom of my boat.
SIKSUKR |
Never seen it warm up this fast. Temp earlier this week had not yet been out of the 50s. Today the surface reached 71 while at 10 feet down it stayed 61. By the end of the day it was 71 at both probes. I tested it with a swim and sure enough, it was a nice swim.
#14 | |
#15 | |
![]() I suspect the winds and passage of time have stirred things up and allowed the colder water down below to mix in. But the overall lake temp has to be much higher than it was a week ago. |
#16 | |
Also, the lake temp is very much affected by the dewpoint (the true measure of how much moisture is in the air.) In the heat wave the dewpoint was around 70 degrees which is about as humid as we normally get. With so much moisture in the air, it prevents evaporation from happening at the lake surface. Evaporation cools things down. Without it, the heat of the last few days was able to get to the water. Now the lake is being hit with NW winds averaging 6 and peak gust of 22 mph so far today. This is combined with a dewpoint that is 39 degrees and dropping. Very good drying day, if you were to hang out some laundry. It's a typical late-September day out there, and the lake is doing what it would normally do in late September-- cooling off by a combination of surface evaporation and physical stirring. |
