Old 07-19-2006, 12:03 PM   #1
T.H.E. Binz
Unhappy Removing Submerged Navigation Hazards
I've got two large rocks about 30' off the end of my dock that have a history of collisions with boat propellers. The size of the rocks (at least what is above the lake bottom) is about 4' x 4' x4'. At full lake elevation, they are about 24" below the surface. One of the largest barge-mounted excavators operating on the lake was unable to move these rocks. I am told that one cannot get a permit from the NHDES to dynamite the rocks.
Does anyone know of a marine contractor, or a drilling and blasting outfit, that could drill holes in these rocks and split them up using expansion agents, rock-splitters, etc.?
I was going to try to expose the rocks during the winter and drill holes for an expansion agent, but the lake was too high and the ice too thin this year!
T.H.E. Binz is offline   Reply With Quote
Old 07-19-2006, 12:07 PM   #2
Onshore
You can get a permit to "pop" rocks from the DES Wetlands Bureau. It would be recommended that you get the permit to either relocate them or "pop" them before hiring a contractor to do the work.
Old 07-20-2006, 01:39 PM   #3
I have no clue about the legality of the following advice.
I have sucessfully moved big boulders on land using chains, big nylon straps, come-alongs and trees. You need to make a lasoo around the rock with the chain and a slipper hook such that the end of the chain comes from the side of the rock opposite the direction of pull, and over the top of the rock. The nylon strap is used to connect to and protect the tree. When you apply tension this way, the rock will roll instead of slide and it is much easier to roll a rock than it is to slide it. If you can make a hole in the ground for the rock to roll into, your problem will be solved without a whole lot of effort or explosives.
You could also make some home made markers for the rocks and leave well enough alone.
They weigh about 6758.4 lbs under water if they are indeed 4x4x4 (and granite). Above water, they would weigh 10752 lbs.
Old 10-11-2006, 10:49 AM   #4
T.H.E. Binz
Angry Rock Removal Denied
For anyone interested, my application to remove the aforementioned rock was denied by the local Conservation Commission. Their suggestion was to move the dock; their main concern was environmental harm and setting prededent. When I look at some of the construction/demolition underway on the lake (i.e., 4,000 SF houses on 10,000 SF islands, tree removal along the shoreline, etc.) I find it pretty ironic that my rock has to stay!
Old 10-11-2006, 11:21 AM   #5
feb
Default DES has last say, right?
Does the local conservation commission have the last say though? I thought DES would take into consideration when the CC says but that the DES makes the final decision. I've seen many times in the DES Decision Reports where the local CC says one thing and the DES still approves the permit.
Old 10-11-2006, 11:47 AM   #6
Onshore
In the State of NH the local Conservation Committees serve an advisory role. They do not have the authority to approve or deny applications as they do in MA. They can make recommendations If they do and the State chooses to take an action contrary to those recommendations the state must explain why through decision findings. The State is not required to follow the Conservation Commission's recommendation.
Old 10-11-2006, 12:07 PM   #7
jrc
How can moving a dock have less environmental damage than moving a rock. Typical bureaucratic nonsense. Maybe the ice will move them for you this winter.
Yankee, the mass stays the same, but the force needed to lift the rock is less in water. Think about a tree, it weighs a ton on land but nothing in water, it floats.
Old 10-11-2006, 12:39 PM   #8
Zeke
Originally Posted by Yankee
Dave,
Why would the rock weigh less under water than above it?
The weight of an object in water, as compared to in a gas environment would be less due to it's specific gravity in comparison in the two envirornments. It still sounds like a damned heavy rock in either state. physics 101
Zeke is offline   Reply With Quote
Old 10-11-2006, 01:06 PM   #9
Seaplane Pilot
Thumbs down Barking up the wrong tree
These Conservation and Wetlands people need to get their heads out of the same sand that they are chartered to protect. Any given weekend dozens of cruisers leaving Mountainview, Silver Sands and the other yacht clubs in Gilford throw up enormous wakes and destroy the shoreline in front of my house on Dockham Shore. Where's the outrage over this shoreline destruction by the environmentalists? Yet moving a boulder is a major problem?
Old 10-11-2006, 01:19 PM   #10
TomC
TomC's Avatar
Default its the difference between "mass" and "weight"..
Dave,
terms which people tend to use interchangeably, but they do not mean the same thing...
Old 10-11-2006, 02:49 PM   #11
I know what you mean Seaplane,I've seen the damage done at your Dockham Shore property.
Old 10-11-2006, 03:12 PM   #12
Any chance you can just mark the rocks well and leave them alone? I see plenty of privately maintained navigational aids on the lake. I can't imagine why marking would be a problem. Of course, being denied the option of moving them seems utterly silly to me. Love to hear a good reason why the rocks should stay.
Old 10-11-2006, 05:37 PM   #13
Lightbulb I'll take it!
Originally Posted by T.H.E. Binz
"...One of the largest barge-mounted excavators operating on the lake was unable to move these rocks. I am told that one cannot get a permit from the NHDES to dynamite the rocks.
I watched one marine contractor "winterize" his steel barge by tying up to his next shoreline jobsite and filling the hull with water. In the spring, he just pumped it out and went on with his work there.
If your marine contractor removes the excavator and empties his hull, he can put a "necklace" of chain under the boulder and raise it off the bottom by pumping out the hull. He could then move it to deeper water.
(Or to my place—I could use a boulder to break up wakes.)
Is it
"Common Sense" isn't.
Old 10-11-2006, 11:41 PM   #14
jrc
I asked the question because I was curious about the answers that I’d get. Let me give you a brief high school level primer:
Don't be so pedantic, we answered the question how it was asked. We explained "Weigh" as an English word on a freindly website, not the formal scientific meaning.
Old 10-12-2006, 07:28 AM   #15
fpartri497
Default yankee
Specific gravity also known as relative density is the ratio of of an objects density (mass/volume) to a reference density, which is usually water but also can be a gas or any other form of matter. It has absolutely nothing to do with the weight of an object, in this case the aforementioned rock.
Weight is the force enacted upon a body (of a certain mass) when exposed to a gravitational field. This is why a person would weigh less on the moon than the Earth, but he would also maintain his same mass. It’s suffice to say, whether the rock is under or above the water, it will have the same mass and since the Earth’s gravitational field is constant, it will have the same weight. So it will be just as heavy no matter where on the Earth that it resides.
You got way to much time on your hands!!!!!!!!
dont worry be happy
Old 10-12-2006, 08:01 AM   #16
Onshore
How exactly do you propose we control that? A speed limit? Maybe a restriction on boat length, displacement, or hull type? Perhaps we should just accept the reality that in this state none of those things will come out of the legislature in our life time and just allow the construction of a wall around the entire lake? If you come up with any good solutions that might have even a remote chance of making it into rule or law please share it with the Wetlands people because we're all fresh out of ideas. (Oh yes, and while your at it, think about how you're going to sell it to those Safety people since they are the only authority that is allowed to regulate boating acting around here and if they won't support your idea it will be DOA.)
In the meantime, someone tell T.H.E. Binz to file a Standard Dredge and Fill Application to move that rock because the Town Clerk must forward that application type directly to the state. It cannot be held by the town.
Old 10-12-2006, 08:23 AM   #17
OK, what would happen if we were to hang the rock on a scale while it's in the water and while it's out? Would the scale read the same weight or not? That was my point. I realize the rock's mass never changed.
Old 10-12-2006, 11:02 AM   #18
Seaplane Pilot
Shore Things: you are correct, it's unenforceable. However, the damage and erosion is real. With that said, why then do the wetlands and environmentalists continually put the screws to people that want to do a minor impact thing such as to move a boulder? Furthermore, if I wanted to put up some kind of solution to mitigate and prevent the erosion to my property, such as to put boulders on the shoreline, (the same property on which I am being taxed), then I would get soundly rejected by the wetlands. I know this is the case because my neighbor tried and got rejected. Wetlands is zealous in its efforts to regulate the small issues, but instead should be focusing on the bigger problems.
Old 10-12-2006, 12:35 PM   #19
skprbob
Default granite
The two-word answer to Dave R and Yankee: Archimedes' Principle.
The more detailed answer:
A 4 ft x4 ft x4 ft block of anything, fully submerged, displaces 64 cubic feet of water. Fresh water has a density of 62 lbs/cubic ft. By Archimedes' Principle, the block would thus have a buoyant force on it of 64 x 62, or 3970 lbs. If the block itself weighed less than that, the buoyant force would be greater, pushing the bnlock up, and the block would float. In fact it would rise out of the water until its weight and the weight of the water it displaces were equal, then sit there floating peacefully; so-called positive buoyancy. If the block's weight and the buoyant force were equal, the block would submerge completely and remain at whatever depth one wished to place it at; so-called neutral buoyancy and very hard to maintain for a number of reasons - just ask a SCUBA diver! If the block's weight was greater than the buoyant force, the block would submerge completely and continue to sink, since the downward force is greater; so-called negative buoyancy.
Example - Concrete has a density of roughly 100 lbs/cubic foot, so a 4x4x4 block would weigh 6400 lbs. That's greater than the buoyant force on it if it were completely submerged, so it sinks. It would also weighs only 6440 - 3970, or 2430 lbs underwater. You have to pour a block weighing over 3 tons in order to get just over one ton of holding weight!
skprbob is offline   Reply With Quote
Old 10-12-2006, 01:30 PM   #20
Well,I just posted a disagreement with Skprbob and then did a little research.He/she is right on with the displacement calculation.By the way,granite weighs 165 pounds per cubic foot.You can do the math.
Old 10-12-2006, 11:12 PM   #21
John A. Birdsall
I think I can see a reason why rocks should stay, specifically only along the shore line which is what I think they are talking about. and that is too stop the errosion of the beaches or land. I say that cause they said to "move the dock" why not find a way to anchor your dock on the rock. My dad often says that an old timer stated sonny if you find anything that can stay in that lake you will make your first million. Well boulders do stay put. Even when hit by boats or propellars.
Old 10-13-2006, 09:38 AM   #22
Rayhunt
Agreed 100% .. these monster boats are the worst problem on the lake. For some reason the pilots have less reguard than anyone else for the rules. I guess it takes too much gas to slow down and then speed up again so they just break a bunch of laws?? Forget the speed limit , the lake needs a 10,000 LB weight limit !
Another favorite of mine is when they run em half speed right up to the no wake sign as the 3 foot waves keep rolling for a half mile past the boat. The area between lockes and pig island needs to be a no wake zone !
Rayhunt is offline   Reply With Quote
Old 10-13-2006, 07:42 PM   #23
Pineedles
Pineedles's Avatar
Default The heck with it
Just blow the damn thing up and take the consequences if any.
Old 10-16-2006, 10:38 PM   #24
skprbob
Talking ostentatious precision
Hi Yankee,
At risk of being ostentatious, pedantic, elitist, and/or haughty, I will say the I probably should have used the term "apparent weight" for the block in the water. However, since you're an engineer, and I'm a former prep school Physics and Chemistry teacher, I suspect we know what the other means!
Old 10-16-2006, 10:46 PM   #25
jrc
jrc, excuse me! We? Do you have a mouse in your pocket or what? Jeesh! For what it's worth, I'd rather be pedantic in a post than haughty, like you....
Not too much time, just an engineer by trade, and a geek at heart!!
I guess, my point was that there are several engineer/geek people on the board that are well qualified to give you a scientific explanation. But since I didn't know a geek was asking, I gave a real world example. I am brusque and rude, but am I really haughty?
Old 10-17-2006, 07:30 AM   #26
Mass, you people are talking about the mass of an object, which doesn't change. Weight is generally a measure of force exerted by an object due to gravity. Weight generally falls under the auspices of f=ma where f equals the force measured (weight in this case), m equals the mass of an object and a equals the acceleration due to gravity. Weight (the measure of force) is also influenced by the medium in which an object is weighed, even air has an effect. Also, although we generally consider the acceleration of gravity to be a constant, it does vary dependant upon your location on the earth. This variation is very small fortunately. The mass of an object is constant no matter where an object is weighed.
A rock, however, will weigh less in the water than on land.
Old 10-17-2006, 08:00 AM   #27
SteveA
SteveA's Avatar
Default David Copperfield?
Maybe David Copperfield could make it disappear... worked for a 747 in 1981.
Another thought, maybe someone could go down to the dock and read this entire thread to the rock.... it may just leave on its' own. Considering that it has been suggested to tow it, drill it and even blow it up..
PS... I'd feel better if someone would admit to having had to look up the word pedantic like I did.
Old 10-17-2006, 11:39 AM   #28
GWC...
GWC...'s Avatar
Okay, just to make your day, since you did such a great job with FFIII - I did, too.
Actually, reading the second definition made it seem an apposite choice.
For those less likely to exert the effort, here's the definition:
pedantic
One entry found for pedantic.
Main Entry: pe·dan·tic
Pronunciation: pi-'dan-tik
Function: adjective
1 : of, relating to, or being a pedant
2 : narrowly, stodgily, and often ostentatiously learned
http://www.m-w.com/dictionary/pedantic
Old 10-17-2006, 01:01 PM   #29
Weirs guy
Weirs guy's Avatar
As a half-an-engineer, I think the real question all of us geeks at heart should be asking is this:
When do we get to blow up the rock, and how much explosives do we get to play with?
Is it bikeweek yet?
Now?
Weirs guy is offline   Reply With Quote
Old 10-17-2006, 01:14 PM   #30
Airwaves
Actually that is a very good idea. If the rock is close enough to do damage to the boat when you come into the dock or leave it, why not look at using the rock as an anchor to the dock, or extending/moving the dock so that it covers the rock? I remember when we had a place on Dockham Shore there was a huge rock just off our dock. It didn't cause us any problem to our boats (I actually named it Big Bertha!) but if it had we certainly could have covered it with the dock itself.
Old 10-17-2006, 01:39 PM   #31
Mee-n-Mac
Mee-n-Mac's Avatar
Wink Aaah the real question
Sadly the answer is probably not as much as you'd like. A few bore holes and just a tiny bit would no doubt do the job. Wasn't there a MythBuster's episode where they re-created the water-in-a-safe + explosives to "crack" it ? I'm thinking T.H.E. Binz might be better off enlisted a squad of UDE rock bass. I mean they must be called rock bass for a reason !? Perhaps they could be enlisted to peck away at the rocks Then it's all due to "nature" and he couldn't be blamed. Until then I' thinking the old Chlorox bottle(s) on a string is a legal alternative.
Mee'n'Mac
Old 10-17-2006, 07:16 PM   #32
A series of holes with wedges tapped in could also be done, has worked for hundreds (thousands???) of years. Probably a little tougher to do underwater though.
Old 10-17-2006, 09:14 PM   #33
Pineedles
Pineedles's Avatar
Default ITD Got the Answer
Exactly, a few wedges and in a couple million years the rock will split. Problem solved.
Old 02-23-2007, 12:47 PM   #34
T.H.E. Binz
Thumbs down The End of the Story . . .
I thought I actually received default approval for the "popping" of the rocks off my dock, i.e., I had an administratively complete application and hadn't heard back from the DES in several months. Unfortunately, DES had mailed a request for additional information to my P.O. Box in Meredith which I never received. As a result, my application was automatically denied and, if I wish to pursue, have to begin the application process (and $100 application fee) all over again.
However, I gather from the request for additional information (which the DES was kind enough to fax me) that NH Fish & Game is not too keen on popping rocks. They don't want rocks completely demolished, but popped to provide a useful size for fish habitat. I'm not sure this is practical for 4' rocks in 5' of water so I probably won't pursue this matter any further. They also wanted a construction sequence showing materials utilized with methods to control turbidity.
Old 02-23-2007, 01:40 PM   #35
GWC...
GWC...'s Avatar
The result of your legal effort to resolve a problematic situation is a sad commentary on life in NH when dealing with state government agencies.
Would seem that the DES and Fish & Game have yet to hear the expression "K.I.S.S." in their daily conversations.
Whatever happened to simple, common sense solutions?
Old 02-24-2007, 10:11 AM   #36
Cow Man
Cow Man's Avatar
Default Hire a pro
For better or worse, I have found that these situations are best handled by a professional contractor. I have used Winnipesaukee Marine Construction. They deal with all the permits and have experience in dealing with the various officials and all the correspondence goes to them.
Sure it's more expensive then DIY but less stressful and it usually gets done!
Cow Man is offline   Reply With Quote
Old 02-24-2007, 11:01 AM   #37
Orion
Orion's Avatar
Default Agree- let the pro's worry about it.
I agree with Cow Man. I am an avid do-it-yourselfer, but when dealing with government agencies, the pros know what you can get away with and how to frame it in the application process. I've used Diversified Marine for several projects and he's always been able to "get 'er done".
This page was generated in 0.15739 seconds
