Old 05-30-2020, 07:59 AM   #1
Lakegeezer
Default Lake Temperature Differences
What a difference in lake temperatures! The NH DES thermometer at Weirs Beach was reading 61 degrees on Friday May 29'th and up in Moultonboro Bay, I measured 75 degrees on the surface and 73, six feet down, using a calibrated thermometer and verified with a swim. That's a big delta!
-lg
Old 05-30-2020, 08:38 AM   #2
Is it possible DES's numbers are inaccurate or reporting a lower depth? They're almost always significantly lower than readings I get in your same area.
Old 05-30-2020, 08:58 AM   #3
Winilyme
68 degrees yesterday 20 inches down in the very churned up Spindle Point area taken on my extremely unofficial plastic, old, likely FLL issue Walmart thermometer. Was 52 degrees just ten days ago when my crazy wife took her inaugural annual dip. Also remember, there was snow in the air just three weeks ago.
Moccasin (05-30-2020)
Old 05-30-2020, 09:33 AM   #4
Default Different locations
The Weirs water is constantly changing, drawing water from the deeper regions in close proximity to the channel.
Temperature gauges at a home dock are relatively shallow water without much current, and often with a sandy bottom, which can help warm the water more quickly.
Just like real estate and businesses, it's all about location, location, location.
Old 05-30-2020, 09:36 AM   #5
Moccasin
Moccasin's Avatar
Default water temps
Thank you both for the posts! We are keeping our eye on lake temps while wistfully distancing...
Moccasin is offline   Reply With Quote
Old 05-30-2020, 10:34 AM   #6
FlyingScot
75--wow! I swam a few days ago, and it was beautiful. But even in my 40 yards or so, there were dramatic swings in temperature every few feet as if there were currents of warmer and colder water. So I would not assert any one number is correct or incorrect
This page was generated in 0.07414 seconds
