Old 08-27-2017, 03:14 PM   #1
Default Stainless Prop and Sand
Quick question: coming into my beach today my stainless prop hit sand for a second or two before pulling my motor up--should I be concerned? I always hear SS props are unforgiving. I looked and couldn't see anything different, not even a "shinier" spot.
Old 08-27-2017, 03:47 PM   #2
If you looked and saw no visible damage, I wouldn't worry about it.
Have fun!
Old 08-27-2017, 04:46 PM   #3
no problem. SS is very forgiving of such things.
Old 08-27-2017, 06:52 PM   #4
icg56
icg56's Avatar
The drive shaft can be damaged with prop looking ok. Hope not, but just mentioning, not forgiving.
icg56 is offline   Reply With Quote
Old 08-27-2017, 07:32 PM   #5
How would I know? It's a Mercury outboard on the back of a tritoon, BTW.
Old 08-27-2017, 08:06 PM   #6
One can do a fair amount of roto-tilling in sand at low power with nothing getting damaged.
If your personal paranoia is seeking a new outlet, I suggest getting the prop shaft run out measured via a dial indicator after your season is over.
I would not do so.
Old 08-27-2017, 08:09 PM   #7
icg56
icg56's Avatar
Last time my kids did this on our Four Winns it was $700 for:
"labor to pull lower unit.replace Inner propshaft, reseal, reshim, put back on boat and lake test."
They noted vibration on inspection.
Old 08-27-2017, 09:45 PM   #8
I'll be taking it out again next weekend and will pay close attention to vibration. It was really deep, soft sand (as opposed to a thin layer on top of hard pack), so I'm hoping I'm OK. Thanks, all!
Old 08-28-2017, 06:22 AM   #9
I assume you were at or near idle speed, if so, and there was no "BANG!" or "CLUNK-CLUNK-CLUNK", there's really nothing to worry about; especially if the engine did not stall, ut if it did stall that's not necessarily bad.
Old 08-28-2017, 06:36 AM   #10
Yes, idle speed, and I shut down/raised the motor within a second or two of feeling it. The ground also dropped off again after the raised section--it looks like it was a higher area from others power loading onto the beach.
Old 08-28-2017, 06:53 AM   #11
Joebon
Joebon's Avatar
You would notice vibration if you damaged the shaft. Also, how do you know it was the propeller that hit and not the skeg?
Joebon is offline   Reply With Quote
Old 08-28-2017, 07:04 AM   #12
Again, from what you describe I would not worry about it in the least. As Dave said above unless you heard or felt a bad clunk or thud it is highly unlikely you did any damage.
Old 08-28-2017, 07:39 AM   #13
Cobalt 25
I boat on Cape Cod that has a LOT of sand. I have run through sand a zillion times with no damage I wouldn't worry about it.
However, a couple of times were to the extreme and clogged the cooling system and I had to disassemble the hoses to clean them out. Not fun.
But really, unless you have vibration or your "engine overheating" alarm going off, don't worry, be happy.
Old 08-28-2017, 08:46 AM   #14
Fingers crossed, thanks everybody!
This page was generated in 0.11185 seconds
