Old 11-03-2010, 03:13 PM   #1
dmjr
dmjr's Avatar
Default M/S Mount Washington on land
I had the opportunity morning to witness the M/S Mount Washington being pulled up on to land. Are there more upgrades taking place this year?
DMJR
Moultonborough, NH
Old 11-04-2010, 02:37 PM   #2
Grady223
Grady223's Avatar
Are there photos available showing the dry dock process this year?
Old 11-04-2010, 05:24 PM   #3
Rag Top Daze
Rag Top Daze's Avatar
Default Maintenance
The ship has been pulled to paint the bottom
I live for a rag top day
Rag Top Daze is offline   Reply With Quote
Old 11-04-2010, 06:09 PM   #4
WeirsBeachBoater
Default Here you go
As seen on WMUR tonight at 6pm.
WeirsBeachBoater is offline   Reply With Quote
The Following User Says Thank You to WeirsBeachBoater For This Useful Post:
Grady223 (11-05-2010)
Old 11-05-2010, 12:02 PM   #5
Pineedles
Pineedles's Avatar
Default Dry Docking vs. In lake
WBB,
I notice that the Mount isn't pulled every winter into drydock. Is there some benefit to leaving in the lake over the winter, or is it just the cost of pulling it up that is the issue?
Old 11-05-2010, 12:38 PM   #6
RI Swamp Yankee
RI Swamp Yankee's Avatar
They pull it out about every 5 years to "kick the tires" ... and do any needed hull work, prop work and paint the bottom.
... or is it every 4 years ... memory it the second thing to fail and I forget what the first is.
Old 11-05-2010, 12:45 PM   #7
webmaster
Moderator
webmaster's Avatar
http://www.winnipesaukee.com/index.php?pageid=drydock
The Following 2 Users Say Thank You to webmaster For This Useful Post:
ILoveWinnipesaukee (11-05-2010), Rattlesnake Gal (11-08-2010)
Old 11-05-2010, 03:37 PM   #8
Pineedles
Pineedles's Avatar
Thanks for the replies. I understand there is a schedule for maintenance. However, my question remains. Is there some benefit to leaving it in the lake over the winter? Most boats are pulled out of the water in the winter, every winter. Isn't it better to pull the Mount too? The bubblers most cost them something to run all winter. Or is this method less costly than pulling it?
Old 11-05-2010, 04:31 PM   #9
Airedale1
Airedale1's Avatar
Where is that?
Old 11-05-2010, 05:02 PM   #10
Newbiesaukee
Newbiesaukee's Avatar
Center Harbor.
Old 11-06-2010, 09:01 AM   #11
WeirsBeachBoater
The boat is much happier in the water, as you can imagine it's best to have the weight distributed across the entirety of the hull surface. On the cradle it is distributed only down the keel and and certain strategic points by bilge blocks.
The Following 2 Users Say Thank You to WeirsBeachBoater For This Useful Post:
Pineedles (11-06-2010), Rattlesnake Gal (11-08-2010)
Old 11-06-2010, 06:24 PM   #12
Pineedles
Pineedles's Avatar
Along with my "thanks", that I attached. I wanted to reply with a thank you WBB. That makes sense. I knew a crew member would have the answer.
The Following User Says Thank You to Pineedles For This Useful Post:
WeirsBeachBoater (11-07-2010)
Old 11-09-2010, 03:29 PM   #13
Grant
Grant's Avatar
They even left it in the water when removing the old and installing the new engines this year. They keep a few heavy-duty bubblers running around it, and it just bobs in its own little pond of open water, surrounded by bob houses.
Old 11-09-2010, 03:34 PM   #14
Pineedles
Pineedles's Avatar
Do they,
Bob Bob Bob, Bob House around?
Old 11-09-2010, 07:35 PM   #15
NoBozo
Do they,
I think that was Steve Allen...Bob Bob Arang... NB
At my advancing age...I can still remember. We had a big 17 inch Black & White Sylvania Halo Lite TV. ....1958..??
Old 11-10-2010, 10:03 AM   #16
Lakesrider
Came out when I was just being born into this world...
That had the florescent front lighting. Now they have LED back lighting....Funny.
The Following User Says Thank You to Lakesrider For This Useful Post:
Cal (11-10-2010)
This page was generated in 0.22045 seconds
