Hi,
I use heat strips in the crawl space of the house to keep the pipes from freezing, and occasionally the power goes out. Anybody know a cheap way to put the power heat strip on some kind of battery backup in case the power is off for several hours? Tx Dan |
How many watts is your heat strip? The wattage is probably way to high for battery backup to be practical. You could use a UPS like what is used for computer backup. But an affordable one will probably only give you minutes.
A better answer is to insulate the pipes. However be careful that the heat strip can be used under insulation. |
You'll find that it is going to be extremely cost prohibitive to try to provide any sort of heat from a battery bank. The current required would kill most normal batteries in a short period of time (shorter than it would take for the pipes to freeze).
A mid-sized generator with an auto-start/auto-transfer switch is the only rational way to accomplish what you want, without a cost the likely exceeds the value. |
#4 | |
I agree on the drain down idea, I think I'll bite the bullet and set it up for a quick drain. I'll install an inside hatch(in the utility closet floor) to get access to the shut off and drain in the crawl space. I just had Basement Systems come in and seal the crawl space, put in french drains and a nice sump pump. I'll need to run a line from the drain to the sump pump, which shouldn't be a problem.
It never ends does it. Thanks for the advice, was hoping to get off easy but I should know better. Dan ![]() |
What do you do about the sink traps and toilet? I can easily set the system to drain all the pipes but there is still water in the pump and filter as well.
#7 | |
#8 | |
