Old 06-09-2022, 04:04 PM   #1
Not to Worry
Default Carrier Heat Pump
I want to install a 4 Ton nominal heat pump system similar to Carrier Co. 25 VNA 048. Or Carrier is fine too. Anyone know a company who can install this OTHER than Lakes Region HVAC.
Any help would be much appreciated.
Old 06-11-2022, 11:10 AM   #2
TheProfessor
It's all right HERE
Of course no one knows if you have the unit. What you are using unit for.
Replacing a unit? Starting from scratch?
Old 06-11-2022, 03:41 PM   #3
Not to Worry
Default Heat Pump
I want to replace my current Propane HVAC with heat pump. I had an engineer review my heating needs and he feels a heat pump would cost far less to run than heating with propane. Even when temps drop below zero.
So, I need a contractor who knows what they are doing AND a company that will service the unit after install.
So, far I have not found a contractor but I do have one that is now working with Carrier to understand how it will all lay out.
This page was generated in 0.16566 seconds
