Old 02-01-2022, 11:00 AM   #1
MRJS
Default Does anybody use a wifi system for an underground propane tank?
Also, who does everybody use for delivery?
Thank you.
MRJS is offline   Reply With Quote
Old 02-01-2022, 11:13 AM   #2
camp guy
camp guy's Avatar
Default Wifi for underground propane tank
In some cases, delivery is related to service, and also related to how much expected usage in involved. Are you talking propane for whole-house use, or for a stand-by generator? Several months ago, Rymes (my provider) came and installed a Wifi gizmo on my 2-tank stand-by propane system (only used for generator) so they could monitor it for delivery purposes since usage is difficult to predict for a stand-by generator. My two tanks are not underground.
MRJS (02-01-2022)
Old 02-01-2022, 11:30 AM   #3
MeredithMan
MeredithMan's Avatar
Default Underground, but no wifi
We use Rymes for both Bedford and Meredith. Bedford is a 1000 gallon underground tank that we own. Meredith is 500 gallon underground tank that is owned by Rymes. We do not have any wifi for either tank; we are on regular delivery, just like with the traditional oil man. For Bedford, they deliver once per month and Meredith every couple of months. We've never had an issue of running out and it's easy to check the gauge for the underground tanks just to be sure they are not getting too low.
MRJS (02-01-2022)
Old 02-01-2022, 02:05 PM   #4
jetskier
jetskier's Avatar
Default We have a cellular monitor
I have a friend who owns a propane company in upstate NY. They use a cellular monitor to determine when to send a truck out to fill tanks. I contacted my provider and received permission to install it on my tank and it has been great.
First, I don't have to dig through the snow to see the status of the tank.
Second, I can access it anywhere on a mobile app.
I told my provider that I would pay extra for the service.
The Following User Says Thank You to jetskier For This Useful Post:
MRJS (02-01-2022)
Old 02-01-2022, 03:18 PM   #5
MRJS
This sounds great! What is the brand you have?
Thank you!
Old 02-01-2022, 06:01 PM   #6
swnoel
They're great when they work...
MRJS (02-02-2022)
Old 02-01-2022, 08:40 PM   #7
Loub52
Loub52's Avatar
Irving installed a cell monitor on our above ground tank last year. Took about 10 minutes from the time they showed, through the installation and confirming the cell signal.
Prior to the cell monitor, Irving was always solid in terms of their estimates of fuel usage to gauge when to fill the tank. Having a whole house generator has given an additional level of confidence knowing that if there are one or more extended power outages, the monitor will reflect an accurate remote tank level and prompt a fill.
I don’t monitor my tank level and don’t pay extra for the feature.
Thanks,
Loub52
The Following User Says Thank You to Loub52 For This Useful Post:
MRJS (02-01-2022)
Old 02-01-2022, 08:55 PM   #8
jetskier
jetskier's Avatar
Default Wesroc
Thank you!
Wesroc is the name of the company
MRJS (02-02-2022)
Old 02-01-2022, 09:05 PM   #9
jetskier
jetskier's Avatar
Post Easy Install
The installation is pretty easy...the visual gauge is replaced with a gauge that is tethered to the monitor (it is 2 screws). My tank is buried, so I ran the cable in a conduit to the monitor. The monitor has a magnet that you remove to activate it and then the fuel provider has to register the unit. Since this is a friend, they gave me access to the app. I suspect that Irving just uses this to monitor the level. I know that the system can provide alerts to the fuel provider based upon how empty the tank is.
Jetskier :-)
MRJS (02-01-2022)
Old 02-02-2022, 09:27 AM   #10
Saw the propane truck backing down the driveway first thing this morning. I am on a on-call with the supplier so I was confused. Long story short, my 300 lb tank as a wifi device. $2.54 a gal
MRJS (02-02-2022)
Old 02-02-2022, 11:38 AM   #11
stingray
I purchased a generac wifii device for above ground dual tanks. The driving reason is from an incident where the tanks leaked out over a couple of days from a faulty refill. Very dangerous situation we unknowingly arrived to. It now provides great situational awareness for a house that is used in an irregular pattern. Wifii connectivity has been erratic at times; likely my router. In the summer with all propane systems off; no pilot; I can see a decrease overtime. Is this typical with others?
stingray is offline   Reply With Quote
The Following User Says Thank You to stingray For This Useful Post:
MRJS (02-02-2022)
This page was generated in 0.12591 seconds
