Old 06-27-2014, 09:45 AM   #1
mountainhouse
Default Recommendation for concrete cutting contractor
Hi all;
New to the forum. We are buying a house near the lake in Meredith and wondered if anyone knows a good contractor, that can cut the poured concrete wall to add in a door and a few windows. This is done all the time with an ICS Diamond Blade Chain Saw.
Thanks.
mountainhouse is offline   Reply With Quote
Old 06-27-2014, 10:25 AM   #2
jmen24
Originally Posted by mountainhouse View Post
Hi all;
Thanks.
L&S Concrete Cutting out of Loudon # 603-798-5300
The owners name is Stacy, tell him Jeremy sent you!
Old 06-29-2014, 08:02 PM   #3
TheProfessor
Hi all;
Thanks.
Not sure but this may require more then a concrete cutter.
As mentioned above - those are the professionals that do cut concrete.
But may not be in the carpentry business.
All can get a tad complicated as the thickness of the concrete is probably not the thickness of the house wall.
You may need a general contractor. Or a good carpenter in addition to the professional concrete cutters.
And a side note. The concrete cutters are a tad messy with lots of concrete dust. Even with a built in vacuum.
Old 07-07-2014, 12:27 PM   #4
mountainhouse
Thanks - L&S Concrete Cutting says they use the ICS wet saws, and the rest is basic header and door and window framing per the latest IBC 2012 code.
This page was generated in 2.45449 seconds
