set point well
Since a set point well only really works close to the water are there any restrictions to putting one in due to the Shoreline Protection Act.
Are there any companies that install them (including an enclosure for well head and pump) |
What is a set point well?
1 Attachment(s)
If you're on a lake, why not just put a suction in the lake and hook it up to a pump and tank? You have that right as a shoreland owner.
Well point location
I have installed well points in locations where there is no water within miles. You can drive them most anywhere and draw water. Using a well point allows the water to be filtered more with it going through the soil. If you set a point 20 to 30' from known water such as the lake will be considerably cleaner from being filtered by the soil, however being close to the lake does not guarantee water at a shallow depth.http://i39.tinypic.com/keuuzc.gif
where to put it.
When we lived in upstate NY, just north of Albany. Our neighbor across the street put in a point well. Our subdivision was probably about 200 feet higher than the Mohawk river, but he got a good flow of water at about 15-18 feet. I asked him how he knew where to drill, and he said midway between two good sized oak trees! I asked him why, and he said that was what he was always told, and it worked virtually every time. Seldom did he not hit water at a relatively shallow depth.
He was a little older than me, and seemed to be really in tune with "old Yankee ingenuity and lore." |
Old horse knows his way home ... or to water
I don't know if these can be "hammered" into the ground by hand or not. I saw one of these down in Maryland being "driven" into the ground....VERY sandy soil not far from the shore (200 yards?) of Chesapeake Bay.
The pipe was about 8 feet long. One fellow held the pipe verticle while another fellow with a back hoe "Leaned On" the top of the pipe with the small bucket, essentially pressing the pipe into the ground. It went right in in one stroke. :) NB |
We have had lake water since 1984. It was supposed to be a temporary thing, but when I used it for washing, dishes, skin and hair, I loved it, it is so soft! I never wanted to give it up. We have all those filters like lakershaker has and have it tested every so often and it is always perfect. I bet a well wouldn't be! We use it all winter and don't have a heater on it. The only problem we ever had was the end tipped over out in the lake one year and was drawing sand so we had to have a diver go down and pick it up. It is buried by the beach and for a bit out into the lake and then just lies on the lake bottom. It is funny because we grew up not thinking of drinking the lake water but I wouldn't give it up for anything now!
We use the lake water as well and similar to tis and lakeshaker we also run it through two sediment filters and a UV filter. It then goes through a carbon activated filter before it comes out of the kitchen faucet and refrigerator ice maker. It tastes great and is super soft!
Dan |
Dan |
Dan |
I really can not comment as I do not know enough UV sterilization to say it is good. However, if it is as good as some say why aren't there lots more using and well companies pushing for purifying well water verse all the tanks/chemicals etc. I know that large companies use it for certain conditions, but that is a lot different than a home use. One thing I do know that the bacteria really grows during the summer months as the water warms up in the lakes and pond. If you believe that you are doing the right thing I would say stick with it, but I defiantly would have it tested by a professional during the warmer months. A good water test will cost about $100 and after having one done I would stick to that person/company for any future as records are great and they will know what to look for. that is just my 2¢ and not intended to be any type of criticism. http://i39.tinypic.com/keuuzc.gif in whatever you do, but please be careful where kids are involved.:) |
Main thing to be on a constant look out for in this area is Radon, from all that granite we have. If you only want to do a water test once a year, perform it in August. That gives plenty of time for the lake to have some use and will give you time to adjust to what needs to be done before you close up the camp. I would not recommend shocking "your" well, Dan. The EPA might have something to say about that!;) |
The August testing sounds like good advice. I will at least be able to tell if my UV system is working properly. Thanks! Dan |
