lubing lug nuts on boat trailer
How to lube the lug nuts on a boat trailer so it will be easier to remove nut when needed, later on sometime.
A plastic beverage bottle with a screw-on cap fits good onto the lug nut. So, press it on and slice the plastic bottle in half which remakes the bottle into a gripe-on funnel. Spay onto lug nut with a spray lubricant to get on and around the nut and bolt and attached plastic 1/2 bottle keeps the spray on the lug nut and off the wheel rim. This has got to be the greatest re-use invention of the empty soda plastic bottle ever made in soda bottle world history! |
Never “lube” lug nuts!
Use anti seize compound located at your local auto parts store.
1 Attachment(s)
A couple of years ago while heading to the ramp for a day of boating I had a small tire issue. The lug nuts were so rusted in place that I snapped 3 studs trying to remove the wheel. I ended up getting it off, buying a new tire, and after installing it I drove home with only two studs with nuts in place holding the wheel on. Kind of ruined my day of boating!
I have different trailers now, but since that day I have taken the nuts off every year and put some grease on the studs. |
| All times are GMT -4. The time now is 10:13 AM. |
