-   Marketplace (https://www.winnipesaukee.com/forums/forumdisplay.php?f=42)
-   -   Looking for a used outboard motor (https://www.winnipesaukee.com/forums/showthread.php?t=28254)
Cal Coon 08-24-2022 11:49 AM
I'm looking for a used two stroke outboard motor for a 17' boat. I am looking specifically for a 20" shaft between 115 and 140hp, no older than late eighties. My preference is Yamaha, Johnson/Evinrude, but will consider other's. Prefer it to come with controls, but not a deal breaker, and it's ok if the oil injection has been disabled. I actually prefer to premix. I'm not looking for any project motor's, I'm looking for something that is in real nice shape, but may be in need of typical maintenance, ie: water pump/impeller, thermostats, lower unit gear oil, etc, etc. That is all stuff I will do to whatever motor I end up buying anyways. It must be able to be demonstrated, (on a stand is ok), and I will perform my own compression test. If anyone knows of something around these guidelines, send me a phone number in a PM and I will make the call, or I can PM you my phone number if you prefer. Thanks for any help in advance.
BroadHopper 08-25-2022 08:21 AM
2 strokes
Fay's Boatyard caters to the sailing community. They may just be what you are looking for! You can also try Dave's Motorboat Shoppe.
