Lake water systems
I was wondering what other people have experienced with this.
I have a good water system that pumps out of the lake all year long. I decided to install a second, back up, seasonal system for irrigation, car washing, and to feed a second building on the property. They are plumbed so that if either fails I can just open a valve and the remaining one will feed everything. The intake is about 40 feet from shore, about 2 feet above the lake bottom in about 6 feet of water It is a fairly busy area for boats. It seems to me that the filters get dirty and need to be changed pretty quickly. I am considering extending the intake to 60 feet out in about 10 -12 feet of water. Still 2 feet off the bottom? Maybe. I am curious where most people pumping from the lake put their intakes or anything they may have learned with years of experience to get the best quality water. If I can't get this a lot better I may consider a well. |
Mine is right next to the dock in a sandy area so it doesn't pick up any sediment usually.It's only in 2' of water so I don't even need to get wet to check it.
Go deep
There are other old threads on this, but the consensus seems to be 10' deep as a minimum. We're only seasonal. We use a well pump underwater, about 18" off the bottom. 10 feet deep at full lake. "Filters? We don't need no stinkin' filters." ( Credit misquote to Cheech Marin) The lab test results give us very high water quality.
Our valve is on top of a concrete block so about a foot off the bottom. It is about 200 feet out from shore, in about 4 feet of water. We have very shallow depths where we are. We tried to run it about 500' out to get real depth but were having issues getting the line to stay on the bottom so we cut it back (full disclosure, my prop cut it back!).
