Seaplane Speed Limits - Split from Boat Fire
Here's a question that I don't have the answer to, but came to mind immediately while reading about this flying fire extinguisher. Wouldn't this plane be exempt from the speed limit rules if it were owned and operated by the state as a fire rescue vehicle?
I don't seriously think the intent of the speed limit law is to ban amphibious aircraft. Plus I'm sure the FAA has some jurisdiction, when it comes to seaplanes. |
Seaplanes exempt
I guess Skip is on Christmas vacation, so I thought I'd drop the reference! |
LakerShaker,
This has been addressed by Skip in another thread. What he says that if you remember civics class, Federal regulations overules state and local regulations. FAA states that Seaplane and amphibious vehicles have to adhere to USCG regulations once they are in/on the water. So it is possible that by federal law they are exempt from any state and local regulations. I hope Skip can clarify this. |
Seaplanes
Broadhopper,
I think if you read what I wrote, we are agreeing that seaplanes would be exempt from any speedlimit or other boating regulation. Hadn't done a search to see if it had been addressed before on the forum, but take you at your word. BTW, USCG regs don't apply on Lake Winni as an inland body of water. |
USCG on Inland waterways
Interesting question. Why do we have to register our boats with the USCG? Your bow numbers are registered with USCG. Also, I remember reading a while back that the USCG wants the state to use the Bouy and Marker systems that they employ on the coast. Then the problem arise that the system they use does not tell a boater which side of the marker they are suppose to go on. This is crucial as the lakes in the Lakes Region are filled with obsticles and the USCG system fails in this respect.
I wonder if there is anyone on the forum that has any knowledge of this??? :confused: |
Seaplanes....
As Broadhopper indicated, this was discussed in another thread, but to sumrise:
Aircraft taking off or landing on a body of water in New Hampshire are exempt from any boating laws that would prevent them from doing so in a safe manner. They are exempted by several State statutes, not because of the FAA. When aircraft are on the waters other than taking off or landing, they are considered vessels and must abide by the applicable NH boating regulations (no wake/speed zones, mooring requirements, etc.) Bottom line, if a speed limit is enacted in NH it will not apply to aircraft taking off or landing. Hope this helped, Merry Christmas, Skip |
I know this may sound dumb but what about those hover craft things??? They are not Registered as boats they are OHRV's
Barefoot....
Aw shucks! I thought we would be able to use a float plane as a tow for barefoot skiing to get around the speed limit issue, but alas, unless we can extend the takeoff run indefinitely, then our tow plane will be considered a vessel! Dangling under the plane after it takes off at the end of a tow rope could be slightly dangerous! :emb:
Good question....
By the way, this does not apply on a body of frozen water....so before someone asks it does not apply to snowmobiles or hovercrafts in the winter. Remember, amphibious aircraft are exempt because two separate state statutes specifically exempt them. No such statute exists for hovercrafts, which do not fit the definition of an aircraft. Merry Christmas, Skip |
sounds like you just invented a new extreme sport
Extreme Measure
I remember a scene on AFV or similar show when a Lake Buccaneer was towing a waterskier. I notice that they brush out the call letters on the plane. Don't know if this is legit or not. But it looks like I may be able to enjoy my favorite sport, barefoot waterskiing! :D
Helicopter skiing
