Water levels
Does anyone know about the current water levels? Trying to decide if we should take one more venture out tomorrow as it’s going to be in the 70s.
1 Attachment(s)
Attachment 16506 Sent from my iPhone using Winnipesaukee Forum mobile app |
Dan |
Almost 22" is crazy! Given that Sunday and Monday look chilly, might be calling it a season for Jettie One!
Dan |
When I come out in the spring, the lake is usually level with the bottom of the dock framing...as of yesterday, it's now exactly 24 inches below the framing.
https://www4.des.state.nh.us/rti_data/WEIN3_TABLE.HTML
https://www4.des.state.nh.us/rti_data/WEIN3_TABLE.HTML, shows the lake 1.87 ft below full lake, or 1 ft, 10 1/2 inches below full lake.
Dave |
So I was looking at the DES website just now....
Winnipesaukee has a 2 ft. normal operating band: Full pool @ 504.32 -- objective to start boating season Memorial day weekend Low pool @ 502.32 -- objective before snow and ice starts to melt Currently according to DES lake is at 502.45... so we are about 23" from full pool "officially" It also means we need to hope for a few things... -- the drought needs to end -- We get a good snow pack over the winter -- spring rains compensate for what the snow pack from the winter is not able to deliver to bring us back up to full pond. I think it is very probable that we will get lower then we did in 2016, where it bottom out at 502.26.... Unless we start to get some rain.... All the lakes are getting very low, which means there isn't much water to get to flow into Winnipesaukee....In 2016, hadn't had a season long drought and the infeeds into the lake, where still able to supply water. |
Taxes
Need to get to full pool quickly before the town increases the property tax due to the additional acreage I've acquired.
Ok that was actually funny. You owe me one coffeeless keyboard. :D
There's Drought...and Drought...
In times of drought in Florida, it's necessary (at some lakes) to mow around the dock. :look:
https://www.boston.com/weather/weath...-massachusetts
So, how does this translate into lake water level next spring? |
Timing
I'm OK with a 2 foot band of full and low water BUT
It ought to be full on August 1 and low in December. I understand the difficulties, but major SNAFU in 2016 and again in 2020 is too frequent. It is bad enough that the lakes region economy suffers from Covid, but sending everybody elsewhere due to low water is a major problem for many businesses as well as local residents. |
Finally, a couple inches of rain
Over 2" of rain has fallen since yesterday (10/17) and the lake is up 1.3 inches in 24 hours. That is a LOT of water! Throughout the day, more nutrient rich runoff will bring up the level even more, but not enough to bring us back to normal.
In a perfect world occasional moderate rain is what's needed but we can't control the weather. |
I've been on one of the lakes water monitoring teams for some time, and the secchi disk readings always show shallower visibility after a storm (A secchi disk is a patterned disk that is lowered into the water until it can't be seen anymore. The clearer the water, the deeper the reading). https://en.wikipedia.org/wiki/Secchi...%20the%20water. We've been getting some of the deepest readings I can remember up until the latest storms. |
lake level
Can someone explain to me (and other bloggers) the function of the dam in Lakeport and its influence on lake level (Winnipesaukee). It has been my understanding that lake level is almost entirely controlled by raising and lowering dam (spillway) height in Lakeport: In spring, in times of heavy rain or snow runoff, the dam is raised to prevent flooding of the Merrimack river. As a result, the lake can go over-full. In the fall, height is intentionally lowered to provide a reservoir for spring runoff. Some years, when its exceptionally dry, the height has to be lowered faster than usual to keep sufficient water flowing into the Merrimack river. In other words, the operators of the Lakeport dam (EPA?) have the power and means to keep the level in Winnipesaukee at a high enough level not to upset boaters. However, this could only be done at the expense of those industries downstream that require sufficient water flow. The latter is obviously the priority (over a few damaged stern drives and impellers). Is what I wrote above even half right?
Dam Operator did OK
1 Attachment(s)
The dam operator can regulate the water, but only if there is water to regulate. The yearly graphic from DES shows that since the Spring, the outflow from the dam was pretty much minimum. They aren't allowed to shut it off completely or several other lakes downstream would suffer.
I don't think we can legitimately complain about the dam operator's decisions. It was a minimum since the middle of May, with a few increases when rain's came. The precipitation was normal through mid-May and the water levels were within normal until late August. In hindsight, the releases in mid-July were probably a mistake, but the data supported it at the time. It was a low rain year and we're still more than 10% lower than normal. Maybe things will average out with a big snow year and then we'll be able to complain about the lake too high next Spring. |
........ 2.3-inches of rain, today, Oct 17, 2020!
2.3 inches of rain fall is a big rain, and that's what the weather page here says has fallen today, Saturday October 17, so will be interesting to see how much the lake level rises in the next day or two, or three.
Probably, the land that surrounds the lake is very dry and will absorb a lot of rainfall before it sheds or drains down hill into the big lake. 2.3-inches of rain recorded at Laconia Airport on Oct 17, 2020; so when was the previous day which had a larger amount? How long ago was that? THE ANSWER: To find an amount greater than 2.3-inches of rain, you have to go all the way back to August 6, 1974 ...... about 46-years ago ...... ha-ha-ha ..... just kidding here ...... have no clue ..... anybody know for real? ..... :rolleye2: |
Rain records from Meredith
1 event with over 5" (10/8/2005) 1 event with over 4" (10/21/1996) 11 events with over 3" (most recent 10/25/2017) 30 events with over 2" |
Dam Flow
As many have noticed the runoff in the spring combined with excess rainfall result in the need to increase the flow at the Lakeport Dam. When that happens, the current in the Weirs Channel increases substantially. That creates a boat safety problem, especially near the bridge because when the Channel narrows the water speeds up even more. Sometimes Thurston's customers as well as people docking and travelling in that area find the current challenging.
Several years ago I called DES to make the suggestion that they increase the outflow between 9 PM and 8 AM when boating activity was very low and cut it down during the day. They told me that was not possible because they only work days. Hmmmm....... |
Need an app
