-   Boat Repairs & Maintenance (https://www.winnipesaukee.com/forums/forumdisplay.php?f=32)
-   -   Dinghy Transom Gasket (https://www.winnipesaukee.com/forums/showthread.php?t=25772)
thinkxingu 05-17-2020 01:01 PM
Greetings!
As some of y'all might remember, a fellow forum member gifted my son an aluminum rowboat last summer. Well, we're replacing the rotten transom this next week and are wondering what to use for the gasket material that goes between the aluminum and wood to seal it tight.
Looking for inexpensive and easy!
Thanks!
Hillcountry 05-17-2020 05:05 PM
Flex Seal! Flex Paste! :D that TV guy seals everything with that stuff! Of course you are going to be using fasteners from aluminum to wood as well. Find screws that will not “interact” with aluminum or rust.
ishoot308 could suggest what screws to use perhaps?
thinkxingu 05-17-2020 05:44 PM
I was hoping to find something in a sheet that I could cut to fit...
Barney Bear 05-17-2020 05:47 PM
Stainless Steel
Stainless steel fasteners are used when connecting different metals. 🐻
ishoot308 05-17-2020 06:13 PM
I would use aluminum screws only. Stainless is an alloy of carbon steel and will eventually react with aluminum especially in a wet environment. If you really must use stainless for its strength, I would use a nylon washer under a stainless washer of the same size, preferably a fender Type washer. This will keep the dissimilar metals from touching. Drill pilot hole through the aluminum slightly over sized to avoid the stainless from touching it as well.
As far as a gasket, I would simply apply a high grade silicone sealant, bolt it together and clean up the excess.
thinkxingu 05-17-2020 06:23 PM
Dan,
Do I need to do the whole back of the transom with sealant, just the screws, or a ring on the outside to seal the "inside"?
ishoot308 05-17-2020 06:31 PM
Originally Posted by thinkxingu (Post 334908)
Dan,
I would put a good circle of sealant around the screw holes on all three areas, outside, inside and middle. I would also pump some sealant in screw holes just prior to installing bolts.
ishoot308 05-17-2020 06:40 PM
And make sure you do not use pressure treated wood against your aluminum.
thinkxingu 05-17-2020 06:44 PM
Right—we have two pieces of oak with multiple layers of L'il-Buddy-applied exterior urethane!
ishoot308 05-17-2020 06:46 PM
Your good to go then!
thinkxingu 05-17-2020 07:09 PM
1 Attachment(s)
[emoji1696][emoji1696][emoji1696]
He got out today, but we had to throw some tape over the transom holes!Attachment 15996
Garcia 05-17-2020 08:30 PM
That's great! So nice to see the next generation explore the beauty of the lake.
8gv 05-17-2020 11:46 PM
My preferred sealant is 3M 4200. It is good for above and below the waterline.
Dave R 05-18-2020 07:31 AM
Mine too. I also like Loctite PL. Seems to be basically the same stuff and is often easier to find in tubes that fit in a caulking gun. They sell it at Lowes.
thinkxingu 05-18-2020 08:11 AM
Maybe a dumb question, but will gutter seal work? I've got a brandy new tube already...
ishoot308 05-18-2020 08:29 AM
I’m sure it will...once you tighten the bolts down and squeeze everything together you're just forming a gasket around the screw holes. No big Deal...
thinkxingu 05-18-2020 09:46 AM
Thanks again!
pondguy 05-18-2020 10:22 AM
Have you named the rowboat yet ? Is that Jetti 1 i see off to the right of the rowboat in the pic ?:D
thinkxingu 05-18-2020 12:46 PM
Jettie One stayed on the trailer yesterday—it was a chill on the beach while L'il Buddy explored kinda day.
As for the name: it came with one that had a history, Harambee, so that will stay. We do sometimes refer to it as Boatie Three, though!
JEEPONLY 05-18-2020 03:19 PM
Great pic
Years and years later it's a bit hard to remember the feelings of a moment like this. However, the memory of the experience doesn't ever really fade.
Good for him/Good for you!
thinkxingu 05-21-2020 06:43 AM
Pictures, lots of pictures.
What I find most hard is trying to remember how this would've felt as a kid. For example, my wife texted me a pic of him anchored just outside the swim area with a laughing emoji—we expected him to head much further out—but for a 9-year-old, that's gotta feel like being in the middle of the lake!
JEEPONLY 05-21-2020 03:28 PM
I'm one of those who learned about boating by "rowing" a wooden, 8-foot boat while it was tied to a dock (three feet of water).
Oddly, I still remember it as being great fun!
