Help with mountain view identification
Hi! Here is the view from the end of Hanson Cove. I've tried a few mountain apps, but I'm not confident what I'm seeing--can someone help? I've also posted a screenshot from one of the apps, but it doesn't seem to work. Finally, the image of what is seen from Major, if that helps!https://uploads.tapatalk-cdn.com/201...30052af4bd.jpghttps://uploads.tapatalk-cdn.com/201...6c5483f492.jpghttps://uploads.tapatalk-cdn.com/201...829fb61093.jpg
Sent from my Moto G (5S) Plus using Tapatalk |
smaller view
The view you are looking at is Sandwich dome on the left to Tripyramid on the right.
Greetings from the other side of Hanson Cove
1 Attachment(s)
Looks like you are using peakfinder. If you are, they just added a cool feature where you can overlay the mountain info on the actual image and save as a photo. You can also align the two, which works like magic. We are around to the north side of the cove, so this is likely what you see to the right in your frame. Peakfinder becomes a lot harder to make sense of when you scroll up (which I think you had done in your image). It's a really useful feature but it is tough to align the mountains to what you see when the viewpoint is changed even a small amount.
Hanson cover from the camp
1 Attachment(s)
I was able to get a pretty good view on Friday. As you can see, Peakfinder is not perfect but the tall peaks are well identified.
That's pretty neat--I'll have to grab that app. Thanks!
| All times are GMT -4. The time now is 02:16 PM. |
