Old 05-21-2006, 11:13 AM   #1
first sight
Default Fuel Tanks
Hi All,
I am a new user and I thought this link would be intresting to some of ya.
http://ledger.southofboston.com/arti...ness/biz02.txt
First Sight
first sight is offline   Reply With Quote
Old 05-21-2006, 09:25 PM   #2
Cal
Cal's Avatar
What a PIA
Old 05-22-2006, 04:56 AM   #3
Mink Islander
Default Agreed
But I'd rather go to some expense and replace the old fiberglass tank on my 83 Montauk than continue to pollute the waters of Winnipesaukee with MTBE...
Old 05-22-2006, 05:44 PM   #4
Captn'J
Default Ethanol and boats.
I heard a lot about this over the past few days. This could be huge for boaters who have older boats. The gas containing 10% ethanol will probabley not get to the lake until mid-summer or so. If you have a fiberglass gas tank you will need to replace it. The ethanol will eat right through it. You should look at your fuel lines and caborator looked at as well, this stuff will gum up your butterfly, pump and engine over a rather short time if it's not up to snuff. I have a 2004 Formula - I called my dealer today to check to see if I am effected by this - luckily I will be OK.
Captn'J is offline   Reply With Quote
Old 05-22-2006, 10:21 PM   #5
Airwaves
Default More bad news
Here is another article from BOATUS on the problem.
http://www.boatus.com/seaworthy/fueltest.asp
Old 05-22-2006, 10:47 PM   #6
Mee-n-Mac
Mee-n-Mac's Avatar
Question MTBE or ethanol at gas docks ?
While the ethanol/gas mixture may be an issue with gas bought from a "land" station, I thought the boat gas docks had already eliminated MTBE from their gas. I didn't think they had replaced it with another oxygenate (ie - ethanol) but I haven't really looked either. Anyone know for sure ? For anyone with old fiberglass tanks, the "solution" might be as simple as using the gas docks.
Mee'n'Mac
This page was generated in 0.30228 seconds
