11-17-2011, 02:52 PM | #1 |
Perception of lake surface (?)
As the air temperature grows colder, I see the lake surface growing more
syrupy than it is in the summer. Some mornings late fall, it seems to be like liquid mercury. Is this perception just because of the darker skies or is the water, in fact, more "syrupy"? Enquiring minds ..... etc.. |
11-17-2011, 05:07 PM | #2 |
It is the lower sun angle and the gray/darker sky. The viscosity of the water does not change. The lake is still six or seven weeks away from icing over.
R2B |
11-17-2011, 05:38 PM | #3 | |
11-17-2011, 05:55 PM | #4 |
I agree Sal. It makes sense that with temperature variations the denseness of water will vary. Water is at it's densest at 39.2 degrees F. Above and below that it becomes less dense. I have often thought that early and late in the year the water acts differently than in the warmer part of the season. I think that it shows up the most while fishing. Subsurface lures sink slower and there is more resistance on retrieval. I also have thought many times that the water does appear to be more "syrupy". I guess it could be the hypothermia though.
11-17-2011, 07:49 PM | #5 |
Enough of this scientific stuff about water density, viscosity, sypupcyness. Just jump in, and see if its harder to swim.
The Following 5 Users Say Thank You to Pineedles For This Useful Post: | ||
BroadHopper (11-29-2011), jkjoshuatree (11-17-2011), Redwing (12-06-2011), sa meredith (11-22-2011), SteveA (11-18-2011) |
11-17-2011, 08:19 PM | #6 |
There used to be a good description of "lake flip" on the Squam Lakes site but it appears to be gone.
While this one is a bit more detailed, it's a good description, by season, of the process. http://www.waterontheweb.org/under/l...ification.html |
11-18-2011, 07:37 AM | #7 |
The question was based on what I see looking southerly from the norrtherly side of Moultonborough Bay, near Buzzell Cove. (although the wonderful images from the "new" Weirs Cam seem to give me the same perception)
11-22-2011, 10:05 AM | #8 |
Despite water being at its highest density at 39 degrees,I doubt a change in viscosity would be measurable by more than microscopic numbers.
SIKSUKR |
11-22-2011, 12:14 PM | #9 |
I think you'll see that in a couple of months it'll be a lot more "syrupy".
11-29-2011, 09:01 AM | #10 |
[I]'m with 2B, it is the sun angle.
11-29-2011, 06:27 PM | #11 |
It does make you wonder...
This is the first year in many that I've been able to spend a significant amount of time at the lake at this time of year. It does seem that the water is significantly calmer most of the time. I assume it is a combination of several factors. Number 1 is probably the lack of boat and human activity on the water. I'm sure that CLA could give us a weather analysis that shows that the winds are either calmer or different (or both) at this time of year. And I do wonder if the increasing density of the water due to temperature has anything to do with it. What I can say is that the lake is beautiful any time of year. This morning when I got up, the water was dead calm, mirroring the mountains and shoreline above, mist hovered over the low lands and valleys, and the sunrise was adding a pink, blue, purple hue to the whole scene. It was beautiful... and unfortunately I didn't have my camera. |
11-29-2011, 06:47 PM | #12 |
I stand by ...
... what I said before. If you have a "critical eye" and spend a lot of time on the water, and are out when the ice breaks in the spring and don't put your boat away until the launch is too slippery to launch, you can see a difference in the waters apparent viscosity.
12-01-2011, 09:19 AM | #13 |
I stand aside..
And corrected.Water density changes much more than I thought with reguard to temperature.First,liquid water is not most dense at 39.2.On the chart I link here it clearly shows a higher density right up to the freezing point.At 70 degrees it has a viscosity of 1 and at 39 degrees it is about a 1.55.Quite more significant than I realized.
http://www.engineeringtoolbox.com/wa...ity-d_596.html
SIKSUKR |
12-01-2011, 11:18 AM | #14 |
SIK, that link shows only dynamic and kinematic viscosity. Searching on that site gives this:
http://www.engineeringtoolbox.com/wa...ght-d_595.html The temperatures are every 10 degrees, but the table does show a maximum in density at "around" 40 F. A better source, such as the ASTM steam tables, gives the density at temperatures more closely spaced. Water is a strange chemical in many ways, relative to other types of compounds. Density is one strange property, having a maximum somewhat above its freezing point, but that is why deep lakes can freeze over, while the heavier water, above the freezing point, settles down toward the bottom. And of course the density of water gets lower still upon freezing to the solid state, allowing it to float on the surface and not sink. |
The Following 2 Users Say Thank You to DickR For This Useful Post: | ||
Jonas Pilot (12-01-2011), SIKSUKR (12-02-2011) |
12-04-2011, 05:35 PM | #15 |
Went over to the island to make sure the lat/lon coordinates haven't changed during the last two weeks. Having read the syrupy thread I concur. It looked surupy, in fact it even sounded syrupy. Then I stuck my finger in the water and it tasted......
12-04-2011, 05:37 PM | #16 |
Tasted like WHAT... NB
12-05-2011, 12:38 AM | #17 |
Did it taste like maple syrup? Maybe I should have pancakes for breakfast and cover them with water from Lake Winnipesaukee. Yum Yum!!!!
The Following User Says Thank You to Greene's Basin Girl For This Useful Post: | ||
Redwing (12-06-2011) |
