Old 10-04-2009, 07:08 PM   #1
Jidge
Default Scary situation in Alton Bay
Saw what looked to be an 16' -18' runabout hull up in Alton Bay today. Wondering if anyone knew what happened. The passengers seemed to be OK. A passing boat brought them aboard their boat. Kind of scary sight to see when you see a boat almost submerged. I think the flotation did its job and Fire rescue was able to tow it to shore.
On a happier note we took a nice slow cruise over to Wolfboro. Lake was like glass and it wasn't too cold. All around it was a nice boat day. Leaves still haven't popped,hopefully next week.
Jidge is offline   Reply With Quote
Old 10-05-2009, 04:52 AM   #2
shamrock
shamrock's Avatar
Default photos
[ATTACH]Name:  boat-2 lg..JPG
Size:  151.1 KB[/ATTACH]
photos of of scary situation in Alton Bay
A Good Snapshot Stops A Moment From Getting Away!
shamrock is offline   Reply With Quote
Old 10-05-2009, 07:17 AM   #3
Default Driving by
Was heading to West Marine in Portsmouth to get my winterization kit when I saw a lot of commotion at the bay. Then I saw the boat sunk in the water. No one seems to know what happen at the time.
Old 10-06-2009, 05:28 AM   #4
Skip
Skip's Avatar
Post Citizen story detailing the accident
This morning's Citizen has a short story detailing the accident that occured. Story can be read by clicking HERE.
Old 10-06-2009, 07:27 AM   #5
Coolbreeze
The dog had a Pfd but the guy didn't. Brilliant!
Coolbreeze is offline   Reply With Quote
Old 10-06-2009, 07:53 AM   #6
MeEscape
Default Questions
I’m glad to see that everyone (and dog) appears to be in good health.
"Marine Patrol reminded boaters as the season comes to an end that shore lines are lower than they are during the summer because of the winter drawback levels. " (Citizen.com article 10/6/09)
So, now can someone tell me, what is the significance of the shorelines being lower than during the summer because of the winter drawback levels?
Also on a different note, who is at fault? The boat operator taking a big wake at 35 mph or the operator of the other boat whose wake (BBW) caused the incident?
MeEscape is offline   Reply With Quote
Old 10-06-2009, 08:01 AM   #7
Kracken
Kracken's Avatar
If the MFG was in such poor shape that a hitting a wake causes a complete structural integrity failure, it is the owner/operator of that boats fault. The boat was obviously not sea-worthy. If the owner/operator was aware of his vessel’s deficiencies, he should be cited and forced to pay restitution to the town of Alton.
Kracken is offline   Reply With Quote
Old 10-06-2009, 08:13 AM   #8
NoRegrets
Our family had a 1968 MFG 16 foot boat with a 60 HP Johnson. The transom rotted out and "broke" our boat in 1978. They were fiberglass over plywood structures. Water seeped in and saturated the plywood in the transom (caused some rot) and froze in the winter weakening the fiberglass..... We were fortunate to discover the problem before hitting a wave. The same construction was used to make the floor and structural members. The article did not say what happened to this particular vessel. I would guess it was something similar.
We are all fortunate the problem happened during this time of the year and not much later or in the spring time when less people are around or the water temperature becomes numbing!
NoRegrets is offline   Reply With Quote
Old 10-06-2009, 07:50 PM   #9
OCDACTIVE
OCDACTIVE's Avatar
This is a very very common issue with MANY boats out there. Some brands you would never ever think would have issues like that and are never checked.
Especially if there have been any changes to the transom such as: custom swim platforms, new hydo-steering, custom trim tab assemby, ext. boxes.... any adjustments not done correctly can cause these issues.
There are very easy ways to check if you have an issue. The best is with a moisture meter. But if you don't have that and you can see your transom through the engine compartment, you can tap the back in a linear pattern with a small tack hammer to listen for voids or strange muffled noises in areas where there shouldn't be. Be sure to look inside the engine compartment for any supports attached to the transom. Obviously these would make different noises when tapped. But a moisture meter is the way to go and not that expensive.
This page was generated in 0.24031 seconds
